Vacuum operated devices
Old Mar 11, 2009 | 11:10 AM
6686L's Avatar
6686L
Question Vacuum operated devices
As many of you know, modern cars in general, and our EX's in particular, use manifold vacuum to power a number of devices.
In the old days, fuel pumps typically had a 2nd chamber to generate vacuum when the engine was under enough load to reduce vacuum.
All of my vacuum-powered devices work fine. ALL of the time EXCEPT for the following:
And here's why I never noticed this before on my '05 EX V-10 4wd - dont normally run at higher throttle settings (nope, not even when pulling heavy loads)
On a long LONG up-hill grade on the Interstate, my air conditioner "defaulted" to "defroster" mode. Soon as I backed off the gas, it went right back to normal operation. Obviously, ran out of vacuum.
Since everything SEEMS to be working just fine, and I dont see any OBVIOUS vacuum leaks, I am HOPING there is nothing wrong.
What about it - guys - do our EX's have some kind of "back-up" vacuum pump to supply engine vacuum to vacuum-controled devices ? If so, does this suggest the thing is failing, and where IS the little devil, anyway ?
Or is this just normal ?
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
winginit
70
Nov 9, 2016 11:15 PM
hillcountryflt
May 2, 2014 09:02 AM
ssanto
1997 - 2003 F150
Mar 12, 2007 07:46 AM
