stalls when i slow down
Old Mar 11, 2009 | 08:26 AM
truckerstyle13's Avatar
truckerstyle13
I have a 79 ford f150 with 300 inline 6 and granny 4 speed trans. The truck starts fine and idles fine and drives fine. But every once in a while when going down the road it will stall when i hit the breaks, like if a car slows in front of me or i go to slow down for a turn. It doesn't show any signs that its going to stall it just does the only way i really notice it is because the steering wheel gets hard to turn. It starts right back up after and continues to run fine. Its got plenty of gas in it, and I can't replicate the problem by hitting the breaks as i drive. It only does this every once in a while, its not a daily problem, its just alittle scary when all of a sudden i loose power steering as i am making a turn. Any idea's as to what the problem is or how to fix it? thanks
Old Mar 11, 2009 | 06:48 PM
flipklos's Avatar
flipklos
Loose wire? Try shaking all the wires involved with your ignition while running at park. Might be simple.
Old Mar 12, 2009 | 08:08 AM
truckerstyle13
Could be Ill try that, I did a google search about it and I read that it could be running to lean so I adjusted the carb and the screw wasn't even out 1 and a half turns. Its hasn't done it since but still it doesn't do it every day. So lets cross are figures. thanks for the help flipklos!
Old Mar 12, 2009 | 08:39 PM
flipklos's Avatar
flipklos
Best way to set a carbs idle mix is to turn the screw in untill idle starts to drop. Turn back out till a max vacum reading is attained. Turn the screw back in 1/2 turn. Idle mix is set. A fellow FTE user taught me that. Works great.
tomwhatley
26
Jul 17, 2015 10:03 AM
94rangersplash
1983 - 2012 Ranger & B-Series
Dec 1, 2011 07:40 PM
daan-o
Mar 13, 2011 10:59 PM
malmz
Mar 24, 2007 12:10 PM
warlord raven
Dec 26, 2003 05:32 PM
