I'd like to point to what Bill said as well as how the propaganda is worded. Thank you for posting that, now I need no picture and know I have that setup as well as the overload. Also please look at how they've diagrammed the two positions; the shortening occurs when the load point of the shackle is moved up, but the spring length is always the same overall, Flex-O-Matic or not.
Edit: I feel like an ***, now. In re-reading it, the advert does say longer springs. I have my doubts.
Reason: Additional info
Flex-O-Matic setup in practice. I can't believe I've had this truck for almost 6 years and never once noticed this strange contraption.
Measures out 55.5" bolt to bolt. I had the other end hooked to the bolt, so take a bit off on the tape.
Now for the 78 F250, non Flex. 54.5", but when I'd measured with the bed, bumper, and tank on, I had 55.5". You take 300-400 pounds off the rear and tell me you won't have a deeper arch that results in shorter bolt to bolt measurements.
I'm pretty sure that despite a 9 year difference and weight differences, these trucks are set up so similarly, I feel it proves the point.
P.S. Bill, you said your books give you load rates, what about dimensions?
Edit: Dangitall if I didn't have to edit this once again. My apologies, Bill, you gave dimensions in post #2.
From their website..
"We are the only spring manufacturer to have been licensed by both Ford Motor Company and General Motors to produce Authentic Factory Replacement Springs and Parts."
Apparently they call them EZ Ride springs but they post a pic for you, complete with measurements... EZ Ride Shackle Tech
regardless of what axle I put under the rear I am leaving my flex o setup I spoke to the guys at the spring shop last week and they said no problem to fabbing up some over load springs.
