1978 - 1996 Big Bronco
Heater noise
Old Mar 10, 2009 | 09:29 PM
xfamousxbyxlifex's Avatar
xfamousxbyxlifex
Heater noise
Alright so check this out i dont get it so some times if i hit my throttle to hard it will kick my heater fan on and it makes hella noise even when the heater is not on does anyone know how i can fix this it is really annoying
Old Mar 10, 2009 | 10:00 PM
flamebuster's Avatar
flamebuster
first off welcome to fte... what kind of rig? could be a wire to heater getting pinched or pulled by throttle linkage have you followed wires from switch to fan? fan has to be getting voltage from a 12v. source, so keep it simple to start with and look for bare wires touching.
Old Mar 10, 2009 | 10:58 PM
xfamousxbyxlifex
It is a 1989 ford Bronco 5.8l beast. there are only like to things wrong with it right now the fan thing and some how i am losing oil with no drip or no burning lol i dont get it.
And thank you for the welcome. i moved over from FSB forums those guys are just straight up rude
Old Mar 10, 2009 | 11:07 PM
flamebuster
My chev does the same thing only about a qt. per 4,000 miles but drives me crazy. And yeah the guys here are super sharp on rigs and very friendly, after all they tolerate me... ha ha seriously though they can help walk a person thru about any problem...so have you done any searching on your fan electrical yet?
Old Mar 10, 2009 | 11:12 PM
xfamousxbyxlifex
no not yet lol i have been kinda busy with trying to figure out how im losing a quart a week not a good thing only thing it could be is blow by but there would be smoke coming out the tail pipe so i dont know what it is
Old Mar 10, 2009 | 11:58 PM
flamebuster
how many miles on it? You could try a 20-50wt. I guess the bright side is it ain't leaving a puddle everywhere.
Old Mar 11, 2009 | 12:00 AM
xfamousxbyxlifex
its got 159k
Old Mar 11, 2009 | 05:50 AM
b4hntn's Avatar
b4hntn
I would also like to welcome you. If the following do not help, others will be along soon more knowledgeable than me.
Is there oil in the air box underneath the air filter? Is oil floating in top of radiator after sitting overnight?
IMO, I would be very hesitant going to 20W-50, but that has been discussed at length here before. Look above to Forums, then Search for tons of good info.
Old Mar 11, 2009 | 08:16 AM
greystreak92's Avatar
greystreak92
I'll second the suggestion to check the breather filter in the bottom of the air cleaner box. A soaked breather is a sign of serious loss of oil control around the rings and valve seals. PCV valve could be part of the problem as well. It's not easy to get to either as it is buried in the valve cover UNDER the upper intake plenum on the passenger side of the engine.
As for the blower fan cutting out, I have one question... can you MAKE this happen with any regularity and with the fan at any speed? Answer this and I may have more in depth suggestions for the cure.
Old Mar 11, 2009 | 12:08 PM
xfamousxbyxlifex
Yes i can make it happen at any time just by romping on my gas pedal. and i dont know what you mean by fan speed it is when the heater is off
Old Mar 11, 2009 | 12:16 PM
greystreak92
Ahh my mistake... I misread it. Thought it was cutting out not coming on. Now that I have severed my rectal-cranial bond, I can say that the guys have you pointed in the right direction... wiring issues more likely under the dash than anywhere unless you have an errant power feed wire flopping around out near the blower motor under the hood.
Old Mar 11, 2009 | 12:27 PM
xfamousxbyxlifex
alright well i will check into the wiring and when i changed my air filter there is a secondary in the air box and it was full of like oily dirt crusted crap could that be a sign of a oil issue?
Old Mar 11, 2009 | 06:39 PM
greystreak92
The secondary filter (under the air filter) is the breather. Before assuming you have a more serious problem, replace it and clean up the crud in the bottom of the box. Replace the PCV valve and keep an eye on it for a week. If the crud and oil returns in short order, you need to consider the possibility that you are losing oil control inside the engine. I know it's not something anyone ever wants to admit but rebuilding is often the only certain cure. But then if it's consuming a quart a week you will save money in oil by fixing it.
Old Mar 11, 2009 | 06:44 PM
b4hntn's Avatar
b4hntn
Yes, disconnect the hose to the little filter in the air box. Crank the engine, lay a small piece a paper over the hose and the PCV system vacuum should hold the paper there at idle. If not, replace the PCV valve.
BTW I saw a mechanic laying over the top of a lifted, F-250 big tires diesel the other day using a great item. I don't know what it is called but it is small extension ladder design with a padded platform attached to the top which cantelevered over the engine. Nothing touched the truck except the mechanic's wrench in his hand. NEAT! and comfortable.
Old Mar 11, 2009 | 08:34 PM
big bad 79 bronco's Avatar
big bad 79 bronco
as far as the oil leak goes i worked at the dealer and on brand new ford's they allowed 1qt of oil loss per 5'000 miles
