Air Suspension Relay
Hey there. Late last night my cksusp light came on...yeah for me. Now, I know I read a thread during my search that mentioned a relay but I sure as hell cant find it now. Anyone know about this?
I had gotten off an 18 hour workday and the memory wasnt doing well.
OH, I should mention, Im looking for info on the relay and wiring....Is there a commn area where this corrodes?
check the right front fender underneith the vehicle between the splash sheild and bumper.there should be a 4 wire connector and the relay.when iu was working at th lincoln dealer we replaced the relay and pigtail connector.
I would check the suspension compressor switch first; it's under the dash just above the passenger side kick panel. Often times, my wife will unitentionally kick the switch which shuts off the compressor, or sometimes if there is a lot of stuff stored on the passenger side floor board, it might hit the switch and turn it off. Just check and make sure yours is not turned off.
Thank you both for your replies. The problem turned out to be the front height sensor. It was replaced...the compressor kicked on and Im back on the road. I found some info on the site that was very informative. Thanks again.
My4Fordtrucks
1978 - 1996 Big Bronco
Jul 9, 2015 10:19 PM
