Sponsored by: Real Truck
Bed Steps
Old Mar 10, 2009 | 08:38 AM
Beach_Bob's Avatar
Beach_Bob
Bed Steps
Has anyone found some sort of step up system for reaching into the bed of our trucks? I keep seeing the F150 commercial and wishing that I could have some sort of way to make it easier to reach in to the bed from the side.
I have nerf bars on the cab, but I haven't been able to find a small one to go from the cab to the wheel well.
Anybody figure a way to do this?
Old Mar 10, 2009 | 08:46 AM
gagnonconsulting's Avatar
gagnonconsulting
I got a bolt on unit from Cabelas, which folds out of the way. Around $50 each. They are small, but with one foot on it and the other on the tire, I can step up and balance well enough to reach into the bed. It bolts to the bed stiffener bar, and is reasonably well made. Although it is mostly aluminum, there is some rust staining after 6 months from one of the steel parts.
Old Mar 10, 2009 | 09:05 AM
hotnanas's Avatar
hotnanas
i step on the tire.
Old Mar 10, 2009 | 09:37 AM
TheBigBee's Avatar
TheBigBee
You can get wheel to wheell bars if you would want to replace the ones you have now they make for a nice clean look. Or the fold aways work quite well you should be able to find some decent sized one to stand on.
Old Mar 10, 2009 | 01:53 PM
I.B. Washincars's Avatar
I.B. Washincars
I have Westin "wheel to wheel" bars on my F-250. They look and work great.
Old Mar 10, 2009 | 02:35 PM
gagnonconsulting
Slightly off topic, but to help get into the bed, I installed a 0" drop hitch insert upside down with no ball and an 18" reciever extender into the square tubing that holds the reciever hitch. I drilled a 5/8" hole to pin the insert into the tube. This provides a "step" off to the (right) side of back of the bed, just in front of the bumper. This is a good postion to step onto the open tailgate without having to get your foot all the way up onto the bumper (I have F350 and a bad hip).
Old Mar 10, 2009 | 02:48 PM
tazo's Avatar
tazo
Old Mar 10, 2009 | 02:53 PM
Futuresweets-10's Avatar
Futuresweets-10
I like that idea.... They make reciever hitch steps, which would be useless when the tail gate is down, but would look great with the setup you have...
Old Mar 10, 2009 | 02:59 PM
gagnonconsulting
Once the hole is drilled in the tubing it also makes a good place to carry an alternate hitch, and it can go on either side. I was planning on welding a bit larger plate to the upside down hight, but ended up not needing it.
Old Mar 10, 2009 | 03:08 PM
mwsF250's Avatar
mwsF250
That, sir, is BRILLIANT!
Drilling a second hole in your extender would allow it to be pushed in and re-pinned to prevent shin whacks when step is not needed.
I love simple, low dollar solutions!
I have an old hitch laying out back.
For those that still have money:
AMP Research > Bed Step™
About The DEBO Step Pull Out Tailgate Step
jt371
Nov 22, 2011 11:25 AM
iron steel
Dec 3, 2009 10:54 PM
jwheatley20
Nov 23, 2009 09:40 PM
brider
Jun 20, 2006 02:43 PM
skidj0003
2004 - 2008 F150
15
Feb 9, 2004 05:51 PM
