vacuum modulator question
Old Mar 9, 2009 | 07:32 PM
fkaster01's Avatar
fkaster01
I've had trouble in the past usually after I get off the freeway and shift out of overdrive, with the trans revving up to about 2500-3000 rpm then slamming into gear. Usually it goes back to normal within about five min. Also when this happens the OD light on the shifter usually blinks on and off until it goes back to normal. I was told that this could be due to my vacuum modulator being gummed up... is this the case or could it be something else?
Old Mar 10, 2009 | 10:31 AM
rattosh51's Avatar
rattosh51
The blinking OD light is flashing a code, so you need to see what code it is.
Old Mar 10, 2009 | 10:35 AM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
If you have the E4OD, there is no vacuum modulator, that tranny is completely computer controlled. Do what rattosh51 said and read the codes, that will tell you what is wrong with your tranny.
IDIDieselJohn
Sep 19, 2011 09:40 PM
IDIDieselJohn
Sep 10, 2011 09:22 AM
xjvince
Mar 24, 2007 01:26 AM
rwsam
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 9, 2002 07:32 PM
Justin03PSD
18
May 28, 2002 07:33 PM
