Help! Smoke on decell
Old Mar 9, 2009 | 11:31 AM
97-7.3dump's Avatar
97-7.3dump
Good morning
I have a problem with my 2000 X. It runs fine with the only problem being it will smoke out the tailpipe only when I decellerate. Its a fairly large plume. It seams to be intermeadiate-coming and going- and worse when warm.
MODs: turbo back 5" ex, open intake, edge tuner. It smokes on all tunes including stock
Ideas? It is sucking oil out of the PVC?? Out of the turbo?? Can it??
Stumpped! It wifeys rig and she wants it fixed and I don't want to go to the stealer ship!
PS no codes on my scanner!!!
Thanks for any Help
Shawn
Old Mar 9, 2009 | 01:35 PM
nlemerise's Avatar
nlemerise
How about just disconnecting the PCV system at the valve cover and see if that solves the problem? If it does, then you know you have a blockage somewhere in that system and you need to find it before you blow seals out of the engine. If it doesn't solve it, then I am not much help to you. It would seem that it could be a turbo problem though.
Old Mar 9, 2009 | 01:42 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
What color smoke? Is your air filter clean? If it only does this on a tune off the Edge, that may be your problem.
Old Mar 9, 2009 | 01:49 PM
97-7.3dump's Avatar
97-7.3dump
Thanks for the replys
It doesn't matter what tune--stock or high Hp. I checked for eccess blowby by removeing the oil filler cap. very little. some one said it could be seals in the turbo??
Any thoughts?
Old Mar 9, 2009 | 02:02 PM
miller_feed
It is possible for the turbo to be leaking oil. Is there oil in the tail pipe? You should be seeing the smoke while accelerating. What color is the smoke.
Old Mar 9, 2009 | 02:06 PM
05chop's Avatar
05chop
If the turbo is leaking oil into the intake you should see oil in the pressure side of the pipes and air/air cooler. Also check down pipe for oil.
Old Mar 9, 2009 | 02:25 PM
97-7.3dump's Avatar
97-7.3dump
Thaks again
I now have oil coming out the tail pipe and I will check the inter cooler pipes to see evedence of oil.
how difficult is it to reseal the turbo??
Can I do it? I'm fairly adept at motors and I'm sure I can remove it.
or should I get a newly rebuilt unit since mine has 160K on it??
Thanks
Shawn
Old Mar 9, 2009 | 02:31 PM
05chop's Avatar
05chop
If its engine oil then your dip stick should read low.What you need to do if you have oil in the air/cooler is remove the air/air and flush it out. Diesel engine can run on oil too! There are good supply of vendors here who can help you out with the turbo parts or complete turbo.
Old Mar 10, 2009 | 08:44 AM
Kwikkordead's Avatar
Kwikkordead
Easy way to verify if the turbo is shot is to remove the intake boot and move the shaft.
It should have almost no movement at all side to side and none in and out.
addybeer
6.4L Power Stroke Diesel
38
Jan 7, 2015 08:29 PM
Jasonszion
Jul 30, 2011 11:16 AM
jefxxo
36
Mar 5, 2009 10:15 PM
txlixerd
Dec 22, 2007 04:42 AM
VQ2Fast4U
Mar 21, 2007 12:40 AM
