Search not working
Old Mar 8, 2009 | 09:55 PM
vettman's Avatar
vettman
Search not working
I'm logged-in and trying to search using key word "oil pan removal", and the returned threads have nothing to do with "oil pan". I searched using different keywords, e.g., "brakes", radius arms, etc., and all such searches return the same threads, and none applicable to the keywords entered in the search field. This is probably not the right forum for this post, so if it's not, will the moderator please post correctly for me.
Thanks
Old Mar 8, 2009 | 10:47 PM
ford truck oldboy460's Avatar
Yeah I been getting pretty much the same results no matter what I search. Put in "pinto" and you come up with the same results as "stroker".
Old Mar 9, 2009 | 06:13 PM
frdavid's Avatar
frdavid
Does anyone know what the problem is with the search function? I've had similar experiences and can't find an answer anywhere.
Old Mar 9, 2009 | 08:21 PM
dlburch's Avatar
dlburch
I entered "oil pan removal" in the search box (with quotes) and got all results relating to oil pan removal...
Old Mar 9, 2009 | 08:26 PM
JBradley500's Avatar
JBradley500
use google... search the topic you want plus ford-trucks.com and then you will get results. you click see more results from (below the link description) and you will see all the options.
