hey everyone, i have 1997 psd witha 7.3L and whenever it rains or i wash the truck the tranny begins to slip. and if it gets warm the tranny does it more frequently. if i am going from a stop the transmission hesitates to shift into the next gear. but if i go under the truck and wiggle the wires the transmission stops and begins to work perefectly again.
Pull the connector and look at it. I was having problems with the tranny shifting, going into limp mode and even dropping into neutral and the highway. I cleaned the VSS in the diff and then the tranny connector was corroded. Cleaned it up and its been fine for the last 6 weeks or so
