Hi.. anyone know how much fluid it takes (quarts) to do a filter/fluid change? also, how do i drain the torque conv.? is there a plug..?1992 f150 4x4 351w w/ e40d trans. when i fisrt take off (cold or hot), i have to manually startout in 2nd. gear, wind her out, then shift to drive. passing on the interstate, i have to manually shift to 2nd. or the engine revs without gaining speed. i hope its just the fluid and filter. i just got this truck, and from what i can see, the filter hasnt been done in awhile.
thanks for any input..
also,,i should mention,, truck has 181,600 miles on it. engine runs super. just need to get this trans. figured out. thanks in advance for any input...
puzzled here.. changed fluid ( 16 qts. mercon v) and new filter. still the same. trans. doesnt slip, just having trouble shifting. has to get upto 35 mph. before it changes. ( overdrive works ) ..?? anyone know the location of the shift solenoid..? that'll be my next subject
[quote=fordguy2009;7300379]anyone know if a 2 wheel drive tranny will fit this truck..? i read/heard somewhere, all i have to do is unbolt the tailshaft on the 2 whl.drive, and install my transfercase in its place.. ?
