Inner fender panels
Old Feb 17, 2002 | 06:46 PM
Todds79's Avatar
Todds79
Inner fender panels
I know this has been posted before but I can't find it. What is the best way to paint or make the inner fenders on a 79 truck look good? They look like they are galvanized, and i would like to dress them up when I repaint the body. Thanks for any advice--- you can see what they look like in the user gallery, 1979 Ford F100 Lariat
Old Feb 20, 2002 | 10:14 PM
TonyG's Avatar
TonyG
Inner fender panels
If I were doing it, I'd use Por 15 as an undercoating material. They offer gloss black/flat black and a silver type color. The flat/semigloss might look ok. http://www.por15.com
Tony
Old Feb 21, 2002 | 11:13 AM
Carlene's Avatar
Carlene
Admom
Inner fender panels
[updated:LAST EDITED ON 21-Feb-02 AT 12:15 PM (EST)]If it is galvanized, make sure you prep the metal real well. I've sandblasted the few pieces of galvanized we used on our '41 until it's down to the natural dull grey look since they're on the outside and will be highly notice if it flakes off.
We had a race trailer a couple years ago and we built the tool/tire enclosure out of galvanized. We were told to wash it down real well with straight vinager and let it dry then the paint would stick. It started peeling about 8 months later and continues to do so.
Maybe someone else in here has a better way to prep galvanized other than sandblasting.
Almost forgot - I agree with using POR-15.
Carlene
Old Feb 21, 2002 | 07:43 PM
restorit's Avatar
restorit
Inner fender panels
I don't have that much experience with galvanized metal, but I just painted a piece of equipment that had a galvanized sheet metal shroud. I used an aluminum / galvanized metal primer I purchased at the local hardware store. I've just painted it, so I can't say how long it will last, but it seems to have taken the enamel topcoat well.
Old Feb 22, 2002 | 09:24 AM
karljay's Avatar
karljay
Inner fender panels
The Jasco "Prep & Primer" from home depot says that it works for this.
"Galvanized: oil-based paint can be applied when Prep and Primer is dry, latex paint can be applied wieht rinsed off within 30-60 min..."
Old Mar 10, 2002 | 05:44 PM
rtwardle's Avatar
rtwardle
Post Inner fender panels
PPG makes a metal conditioner for steel and galvanized metal. Read the instruction before use because there are 2 mixing ratios one for metal and one for a galvanized coating. Note on sandblasting: you can not use some metal conditioners after sandblasting. PPG makes a conditioner that has a phosphorus base that is left behind after the application process. If you use this type of conditioner any coating will not stick. You need to wipe on the conditioner and remove it with clean water. With the phosphorus conditioner you will not be able to remove the phosphorus residue that stays in the pits from the blasting process. Be clear when you order these products and question the staff selling them to you.
Old Mar 10, 2002 | 08:41 PM
76RangerXLT's Avatar
76RangerXLT
Inner fender panels
Branded
Oct 31, 2016 11:02 AM
78 PEB
28
Oct 29, 2016 09:05 AM
3twinridges
Apr 23, 2016 05:54 PM
LARIAT 85
Sep 16, 2015 08:12 PM
FatherDonald74
Escape & Escape Hybrid
Jul 25, 2015 08:40 PM
