Head Gasket
Old Mar 8, 2009 | 11:02 AM
polarisman729's Avatar
polarisman729
Head Gasket
Hey Guys, I have a leaking head gasket on my 6.9. I should have the head off today. (I'm glad thiese engines come apart easy) When I got the engine, I installed ARP head studs in it. MY question is, when i get the head off, what should I look for that is causing it to leak? My guess is one of three things: cracked head, warped head, blown gasket. THese sound right? Can these heads be milled? I know that the only space between the head and the piston is the head gasket. Well, I've got work to do!!
Old Mar 8, 2009 | 07:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Did you follow ARP directions when you installed the studs?
Run up to specified torque a minimum of four times in steps, then remove them again in steps before you run them up to torque the last time.
By following this I probably wound up with almost 2 full turns more on the nuts.
The other thing, absolutely no oil contamination of either the head, gasket or block surfaces when you install them.
Very sparing application of moly assembly lube on the studs only before you torque them down.
Are you running a turbo?
How much boost?
Can you see leakage?
What are the symptoms you are seeing?
There are service limits on how much you can surface either the block or heads.
Old Mar 8, 2009 | 11:22 PM
Wookie35's Avatar
Wookie35
You should be able to tell where the leak is coming from one you have the head off by looking at the gasket closely. I just had mine off and even though I already new where the leak was coming from, I was able to see on the gasket where the leak was at.
Old Mar 9, 2009 | 11:15 AM
polarisman729
Yeah, I got the head off and can tell it is most likely the gasket. Dave, when I got the studs there was only a piece of paper giving torque specs and nothing that said the process. Maybe why the gasket leaked. I'm not running a turbo yet. Thanks.
Old Mar 10, 2009 | 08:48 PM
Dave Sponaugle
What did you torque them to?
I followed the stock torque down pattern and used 4 steps at increasing torque setting for each install.
Then I removed them again following the stock pattern and removed them in 4 steps also.
Repeted that three more times before I did the final install.
That was one evening shot just getting the heads on.
But if you look at torquing them down 5 times each, that was a lot of bolts to torque down.
007bronco
May 5, 2014 04:03 PM
thebigk
1997 - 2003 F150
15
Apr 5, 2013 07:06 AM
MudDan
13
Jan 13, 2012 01:06 PM
B Dobz
Aerostar
16
Jan 22, 2011 09:32 AM
PlayMechanic
3.8 & 4.2L V6
Nov 19, 2010 11:00 AM
