TestinG VGT
Old Mar 7, 2009 | 11:01 PM
hacksaw830's Avatar
hacksaw830
TestinG VGT
How do you test the vgt? can I use a multimeter? what should the values be?
Old Mar 8, 2009 | 01:26 AM
cartmanea's Avatar
cartmanea
Do you think its not working? It either will be working or it will be a complete dog under 2000-2500 rpms. Try unplugging the VGT actuator and see if the problem gets worse, if it doesn't then it is working.
Old Mar 8, 2009 | 08:52 AM
hacksaw830's Avatar
hacksaw830
Its just the opposite, the truck runs like its supposed to up to about 1500-2000 and then its like it has no boost. it takes for ever to get to 60 mph and all I can get going down a pretty steep hill is 75 maybe 80 then going uphill its back down to 35-40. I have no smoke and it cranks and runs fine, just no power, I was told I have an exhuaust leak but I cant feel air leaking anywhere.
Old Mar 8, 2009 | 11:26 AM
tex25025's Avatar
tex25025
If you had autoenginuity with the Ford enhancement package, you could get it to test the VGT. That would be the only way that I would know, unless you have PT DIAG(which I highly doubt).
Old Mar 8, 2009 | 12:18 PM
Wyatt66f100's Avatar
Wyatt66f100
sounds like a turbo issue but your vanes are just stuck in a different position then everyone elses. have you had it rebuilt before?
Old Mar 8, 2009 | 05:13 PM
hacksaw830's Avatar
hacksaw830
Got it fixed
Thanks for the help but it was loose intake manifold bolts on the passenger side. Shes running like a raped ape now
Old Mar 8, 2009 | 05:51 PM
tex25025's Avatar
tex25025
Always the simple things that get us.
Old Mar 9, 2009 | 09:31 AM
Wyatt66f100
wow never herd of that from factory. did a tech leave them loose?
Old Mar 9, 2009 | 09:55 AM
hacksaw830's Avatar
hacksaw830
No! I had removed the egr cooler to block it off. It was my fault, but I do think my intake manifold may be warped because when I tried to re-torque it per factory specs, The #1 bolt would be loose again I had to re-tighten/torque the bolts about 5 times before the bolts would stay tight. I had followed the suggested pattern the first time I tightend them but I did not go back and re-check the bolts after I had installed the manifold, lesson learned on my behalf, dont get in a hurry!
