CCV Parts ....HELP
Old Mar 7, 2009 | 09:46 PM
THEDON117's Avatar
THEDON117
Exclamation CCV Parts ....HELP
I'm in need of a piece of 4" diameter pipe for the CCV mod. I can't find it any where. Was out looking all day for parts couldn't find anything. If anyone still has some left over from an exhaust I sure would like to know and I would be willing to pay for it.
I also need a detailed list of the sizes of fittings and hose for this as well. Any help and info would be greatly appreciated. Thanks.
Old Mar 7, 2009 | 10:02 PM
megawatt00's Avatar
megawatt00
Shoot Clay at Riff Raff Performance a pm. He is putting together a kit that will have everything that you need.
Old Mar 7, 2009 | 10:16 PM
afonda's Avatar
afonda
this is a good mod...
I found my parts at "Liberty Equipment". They are a local shop here in Fredericksburg, Va. that services Bobcat and other heavy equipment. They had the 4 inch exhaust pipe and also had 3/4 inch ID (inside diameter) oil resistent hose.
The hose was like $2 a foot and the 4 inch pipe was cheap.
I got the pvc stuff at Lowe's Hardware and used the filters for your floor vents in your house for inside the pvc.
Old Mar 8, 2009 | 12:33 AM
dmueller71's Avatar
dmueller71
it's been a year or so since I did the CCV mod, but from what I remember, I didn't need a piece of pipe. I remover the ccv from the stock intake tube, cleaned it out, sanded the fittings flat, and filled the hole with what I believe was a 5/8" or 3/4" carriage bolt from the inside. I siliconed it in and nutted it from the outside, and have never had a problem. Just make sure that you rout the hose to somewhere where the smell won't come up into the cab. I ran mine to the running board on the drivers side, and with the windows open, I sometimes see the smoke, and it smells like trans fluid burning.
Old Mar 8, 2009 | 10:33 PM
THEDON117's Avatar
THEDON117
Well I would still like to get a piece of 4" pipe to put in their. Anyone on here have any they want to sell or knows of someone who has some scrap? I'm still trying all the local shops and truck yards I know of. Please let me know if anyone has some. Thanks guys.
Old Mar 9, 2009 | 07:44 AM
Ponyboychris's Avatar
Ponyboychris
Here's my kit and instructions that I built.
CCV Mod pictures from trucks photos on webshots
Old Mar 9, 2009 | 08:41 AM
brian42's Avatar
brian42
Veteran: Navy
I'm surprised that a local muffler/exhaust shop doesn't have some 4" scraps lying around, especially if they work on trucks.
Old Mar 9, 2009 | 09:29 AM
Ponyboychris
If all else fails, you can get a chunk of 4" pipe from these guys.
Exhaust Tubing
Old Mar 9, 2009 | 01:47 PM
THEDON117's Avatar
THEDON117
Thanks for the help guys. Do we need a 4" ID or OD piece of pipe for the Mod? Since I still can't find any at the local shops I guess I will go this route and order it. Thanks for the website Chris.
Old Mar 9, 2009 | 02:43 PM
superduty4x4's Avatar
superduty4x4
4" OD is what you want.
Old Mar 9, 2009 | 03:37 PM
riverrat41's Avatar
riverrat41
I have some 4'' stainless pipe if you want some.It is less than schedule 10 thickness.I used it on two so far to retrofit for ccv and 6637.
Old Mar 9, 2009 | 03:57 PM
Ponyboychris
Yup, 4" OD is what you want. Polish it up nice a purdy like the IC tubes.
Old Mar 9, 2009 | 08:18 PM
strokersace's Avatar
strokersace
I've got the piece I built that bolts up to the factory bracket. Painted black to blend in. I had to replace it cause I installed a larger compressor housing with 4" intake tube and it wouldn't bolt back up for some reason. If you pm me your address, I'll throw it in the mail.
Here's some pics:
Old Mar 10, 2009 | 10:16 AM
superduty4x4
Ryan what did you end up replacing it with? Nice offer BTW!
Old Mar 10, 2009 | 10:18 AM
strokersace
Another piece of 4" SS pipe. I painted it black too. It looks identical to this one but with no mounting flange welded to it.
