[quote=94 F250 supercab;8008408]IS the PSOM a replacable part by itself or is it esaier to replace the whole instrument cluster ?The PSOM can be replaced.
Originally Posted by 94 F250 supercab
How much does the PSOM cost or the whole cluster new ?
About $400.00 at a Ford dealer other have said if I remember right.
That the right way to do it but some just go to a salvage yard and pick up a cluster for about $30.00 (the kind without the tach, tach ones cost more) and take the PSOM out of it and put it in the cluster in your truck.
Thanks for reply, went to dealer they said it wasn't available anymore ?
Junk yard said $75.00 with tach
Will any year 92-95 150 or 250 instrument panel work if they look the same ?
Does it matter what size engine was in the vehicle ?
Yes with or without tach, F-series or E-series and Bronco.
But they were improved in 1994 so you may want one from a 1994-1996.
i know ford recalled the speedo thing... something about catching the truck on fire even if it wasn't running... i don't think that would be your problem though
thats funny i just got a notification from ford today about this recall.
Is not that recall about the Speed Control and not the Speedometer?
That would have nothing to do with the PSOM.
It is about the pressure switch on the Master Cylinder and its wiring.
yep thats the one. said ther is a possiblity of fire even with the key off.
couldn't believe that i got the notice since i am probably at least the third owner.
