Air in power steering system
Old Mar 6, 2009 | 07:28 PM
hotrodmerc's Avatar
hotrodmerc
What is the best way to get air out of the power steering system? I understand this can be quite difficult.
Old Mar 6, 2009 | 07:42 PM
dustybumpers's Avatar
dustybumpers
at an idle, keep turning wheels lock to lock{full right to full left}, add fluid as needed. Shouldn't take more than a couple of minutes. do not over fill.
Old Mar 6, 2009 | 10:57 PM
EPNCSU2006's Avatar
EPNCSU2006
It works best if you can do what dustybumpers suggested with the front end off the ground on jack stands.
Old Mar 6, 2009 | 11:36 PM
88n94's Avatar
88n94
True. A properly placed full size floor jack will raise both front tires off the ground much simpler than messing with jack stands. On a 4X4 just put the floor jack under the front pumpkin.
