oil cooler
Cooling System Draining, Filling and Bleeding
Draining
WARNING: Never remove the pressure relief cap while the engine is operating or when the cooling system is hot. Failure to follow these instructions can result in damage to the cooling system or engine or result in personal injury. To avoid having scalding hot coolant or steam blow out of the degas bottle when removing the pressure relief cap, wait until the engine has cooled, then wrap a thick cloth around the pressure relief cap and turn it slowly. Step back while the pressure is released from the cooling system. When certain all the pressure has been released, (still with a cloth) turn and remove the pressure relief cap. Failure to follow these instructions can result in personal injury.
CAUTION: The coolant must be recovered in a suitable, clean container for reuse. If the coolant is contaminated, it must be recycled or disposed of correctly and the system filled with new coolant.
CAUTION: Some vehicles cooling systems are filled with Motorcraft Premium Engine Coolant VC-4-A (in Oregon VC-5, in Canada CXC-10) or equivalent meeting Ford specification ESE-M97B44-A (green color). Others are filled with Motorcraft Premium Gold Engine Coolant VC-7-A meeting Ford specification WSS-M97B51-A1 (yellow color). Always fill the cooling system with the same type of coolant that was drained from the system. Do not mix coolant types.
NOTE: Less than 80% of coolant capacity can be recovered with the engine in the vehicle. Dirty, rusty, or contaminated coolant requires replacement.
Place a suitable container below the radiator draincock (8115). If equipped disconnect the coolant return hose at the fluid cooler.
Remove the fill cap from the degas bottle.
Open the radiator draincock. Remove the cylinder drain plug, if equipped, to drain the coolant from the cylinder block (6010 </TD></TR></TBODY></TABLE>Coolant Article
you will also want to drain the oil and keep the oil plug out..when you pull the cooler off some water may go into the block..if it does it will come out the oil plug..
i have a PDF file with all instructions on removing and re install with TQ's also has spec's on rebuilding the cooler.. but it cant be posted here..file to big..PM me your address and ill email it to you..
https://www.ford-trucks.com/forums/7...l-coolers.html
thanks
<TABLE class=tabletext cellSpacing=0 cellPadding=3 width="100%" align=center border=0><TBODY><TR><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top>oil cooler, f350, 7.3l diesel
</TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top noWrap align=middle>99-03 </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$286.40</TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right> </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$206.21 </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #3333cc 4px double" colSpan=5><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tabletext>
Fuel system - Fuel induction - Turbo charger - Oil cooler </TD><TD class=tabletext noWrap> </TD><TD class=tabletext noWrap align=right>
</TD></TR></TBODY></TABLE></TD></TR><TR><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top>oil cooler assy - 5.4 liter - 5.4 liter </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top noWrap align=middle>99-01 </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$174.98</TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right> </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$125.99 </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #3333cc 4px double" colSpan=5><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tabletext>
Cooling - Oil cooler - Oil cooler assy </TD><TD class=tabletext noWrap> </TD><TD class=tabletext noWrap align=right>
</TD></TR></TBODY></TABLE></TD></TR><TR><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top>oil cooler assy - 6.8 liter - 6.8 liter </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top noWrap align=middle>99-07 </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$174.98</TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right> </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$125.99 </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #3333cc 4px double" colSpan=5><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tabletext>
</TD></TR></TBODY></TABLE></TD></TR><TR><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top>oil cooler - 7.3 liter turbo diesel - 7.3 liter turbo diesel </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top noWrap align=middle>99-03 </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$286.40</TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right> </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$206.21 </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #3333cc 4px double" colSpan=5><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tabletext>
Cooling - Oil cooler - Oil cooler </TD><TD class=tabletext noWrap> </TD><TD class=tabletext noWrap align=right>
</TD></TR></TBODY></TABLE></TD></TR><TR><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top>oil cooler adapter - 7.3 liter turbo diesel - 7.3 liter turbo diesel </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top noWrap align=middle>99-03 </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$4.52</TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right> </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$3.53 </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #3333cc 4px double" colSpan=5><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tabletext>
Cooling - Oil cooler - Oil cooler - O-ring </TD><TD class=tabletext noWrap> </TD><TD class=tabletext noWrap align=right>
</TD></TR></TBODY></TABLE></TD></TR><TR><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top>oil cooler seal - 7.3 liter turbo diesel - 7.3 liter turbo diesel </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top noWrap align=middle>99-03 </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$11.12</TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right> </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$8.68 </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #3333cc 4px double" colSpan=5><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tabletext>
</TD></TR></TBODY></TABLE></TD></TR><TR><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top>W/oil cooler - 5.4 liter - 5.4 liter </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top noWrap align=middle>99-00 </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$176.00</TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right> </TD><TD class=tabletext style="BORDER-TOP: #3333cc 4px double" vAlign=top align=right>$95.04 </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #3333cc 4px double" colSpan=5><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tabletext>
Engine - Engine parts - Oil filter - Adapter </TD><TD class=tabletext noWrap> </TD><TD class=tabletext noWrap align=right>
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
