2.5" AS Leveling Kit
Old Mar 6, 2009 | 05:42 PM
broncobran68's Avatar
broncobran68
I ordered a 2.5" leveling kit from autospring. It should be here tonight or tomorrow I hope. I read a really good write-up on F150online and as a result I'm heading to the store right now for a 30mm socket and pitman arm puller incase i decide to use them. I have air tools so hopefully the install will go well. Here are some before pics:
Old Mar 7, 2009 | 07:13 PM
broncobran68
I got the driver's side all apart but cant get the strut assembly back in. Anyone have any ideas?
Old Mar 7, 2009 | 08:29 PM
broncobran68
Okay figured out the problem: the 08s used an aluminum lower control arm while the 09s use steel. The steel one has extra support around the lower strut bolt holes preventing the strut/spacer from sliding right back in.
A picture says a thousand words:
I guess I'll try using a spring compressor?
Old Mar 8, 2009 | 11:14 AM
silver05fx4's Avatar
silver05fx4
well know on my 05 i had a heck of a time geting it back in some do use a spring compresser to help
or u could just get a 1.5 inch kit
Old Mar 8, 2009 | 03:50 PM
broncobran68
Well i got it done. Had to use a spring compressor and then still pry the strut back into place. Was quite a pain. The rest of the install was easy though. Here is a crappy after pic:
Old Mar 8, 2009 | 04:03 PM
rockstate45's Avatar
rockstate45
Dude, that'll look badass with some tires!
May I make a suggestion? Maybe toss a 1" block on there (the pic really isn't clear enough for me to make an assumption of it's nose high at all).
-rockstate
Old Mar 8, 2009 | 04:13 PM
broncobran68
-rockstate
thanks. i'm gonna hold off on the tires. 35s or so eventually. the truck only has 700 miles on it. i'm thinking about going an inch higher in the rear although its hard to tell at this point. i'll get better pics when the weather improves.
Old Mar 8, 2009 | 04:15 PM
rockstate45
Awesome! I can't wait for 'em. I love the look of a leveled truck.
You gonna put a bumper on that thing?
Oh yeah and how'd the spacer mount? On top of the strut or in between?
-rockstate
Old Mar 8, 2009 | 04:18 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
Make sure u take it in and get it re-aligned, from the pic it looks a bit high in front is that an illusion
Old Mar 8, 2009 | 04:23 PM
broncobran68
Yeah its going in first thing tomorrow for an alignment. The spacer mounts on top of the strut assembly. I am not planning on a bumper unless something catches my eye. And i cant tell if its level or not because the driveway is sloping and i'm not going outside because its snowing. Time will tell.
Old Mar 8, 2009 | 06:04 PM
fonefiddy's Avatar
fonefiddy
It does seem a touch front high?
It might just be the way the truck is sitting on the sloped driveway?
Old Mar 8, 2009 | 07:43 PM
silver05fx4
well glad to see you got them in there ...but i think some bigger rubber might be in order
Red Ford Truck
Ontario Chapter
39
Oct 26, 2012 06:36 PM
drey04
Jul 16, 2010 09:56 AM
460429_freak
Missouri Chapter
May 14, 2009 01:56 PM
ExcursionMan
Jun 17, 2008 03:03 PM
axl_james
3.0L V6
Jul 30, 2003 09:57 AM
