injector help needed
Old Mar 6, 2009 | 05:36 PM
Wookie35's Avatar
Wookie35
How do you get the copper washers off of the injector tips, or do I really need to replace them?
Old Mar 6, 2009 | 05:46 PM
starmilt's Avatar
starmilt
If you are replacing the injectors I would replace them.
If you are just doing the return line T's I wouldn't mess with them.
Old Mar 6, 2009 | 11:53 PM
S.P.'s Avatar
S.P.
I used plyers.. grab and twist... just be carefull not to hit the inj. end...
Old Mar 7, 2009 | 05:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If the injectors are removed from the engine, you should replace the copper washers.
That is about the only time they need replaced though.
