Mechanic thatis stuped
Old 03-06-2009, 06:32 AM
ranger81's Avatar
ranger81
ranger81 is offline
I have a 98 2.5l ford ranger resently i was driving and the o/d light started to flash and when stop and then try to go you can feel the tranny slip so i checked the fluid it was clean no burnt smell i found if i down shift the tran dosent slip as bad i changed the abs sensor on the rear pumpkin and the fluid and filter i drove the truck after i did all that and when the truck is cold or been siting for a while that it drives fine and shifts fine and no flashing o/d light but when it gets warm than it starts to act up im a mechanic but not that good with trannys any help would be great
Old 03-06-2009, 05:56 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
If it gets worse with warmer engine (ATF fluid) temps, then I would guess it's either a line pressure issue, or a problem with the overdrive itself.
In any case, I think you might need a tranny specialist on this one.
Old 03-14-2009, 04:30 PM
ranger81's Avatar
ranger81
ranger81 is offline
well that is what i was thinking
Old 03-14-2009, 07:03 PM
Pablo-UA's Avatar
Pablo-UA
Pablo-UA is offline
try to ajust OD band. but usually it works for 30-50K.
Old 03-14-2009, 10:25 PM
ranger81's Avatar
ranger81
ranger81 is offline
i didnt think the od band was adjustable ?
Old 03-14-2009, 10:29 PM
racsan's Avatar
racsan
racsan is offline
drive it in "D" (overdrive locked out) and see if you still have issues, if you do its more than a overdrive problem. thats about all the help i can be, im more of a manual-trans person.
Old 03-14-2009, 10:54 PM
MFJ's Avatar
MFJ
MFJ is offline
If the O/D off light starting flashing, there is some internal problem. At least the computer is telling you, before it takes a dump on you. On my Windstar, it threw a couple of codes. A piston inside was not right, and something else. Time for a trip to the transmission shop.
Old 03-15-2009, 04:23 AM
Pablo-UA's Avatar
Pablo-UA
Pablo-UA is offline
well, gentelmen, lets try to solve problems with tranny on truck first. What we can do? Ajust OD band, change OD piston, its internal sealing (2 o rings on "stick").
well, we can also drop valve body and change some valves, pistons... the next step is to drop a tranny.
but ones I pulled out OD servo piston and 2 small part fall down in tranny and I had to drop tranny anyway.
Well, OD band change requires to remove bellhousing and valve body. so 3 new gaskets... so there is a reson to change OD clutch pack too.
ok! but... as experience say, do all tranny rebuild, becouse I changed OD band first and got 2nd gear sliping, chnged band #2.... and a year later I got no reverse becouse of worn band, so there is reason to change all and be sure your tranny will run fine for next 5 ore more years.
