You need a COUPLER, not a piece of pipe! PVC and ABS is measured ID (inside diameter) and has a 1/4" wall, so a 3" piece of pipe is 3.5" diameter. When you buy the coupler for a 3" pipe, it also has 1/4" wall so you get 4" OD (outside diameter). This will get you by, but you are choking down the size of the intake to 3" by doing this. Get some exhaust tubing if you can help it. I will have some extra tubing here shortly, but it won't be all fancy powdercoated like what Clay is offering.
I had mine come off a few days ago. I don't even want to think how long it was like that.
The only thing that I can figure out is that the cold weather caused the filter to come loose. I have had the same filter on since last spring and this is the first problem I have had.
