Injection Pump
Old Mar 5, 2009 | 08:25 PM
asleiman's Avatar
asleiman
Injection Pump
The pump is on the 89 F350
IP advance plunger can be fixed the pump while it is mounted
Thsi what I did today , it was stuck , just 2 hours taking off the advance lever and vacumm , then you can the nut at the bottom of the pump .
it come off with box end 1" . once it is out it easy to unstick the plunger , plus some polishing and WD and it is back like a charm
Old Mar 5, 2009 | 09:22 PM
PLC7.3's Avatar
PLC7.3
Good job..... just remember to use a very good lubricating fuel additive to ensure it does not stick again.....I use Howes Diesel Treat and have found mine to run much better with better fuel mileage.......
Old Mar 6, 2009 | 07:33 PM
asleiman's Avatar
asleiman
I got that problem fixed
I am still having problem cold starting wit out using the block heater even in 40 deg such as today.
Still have few problem:
1- I know the glow plugs controller is suspect and sepcially now that I only have seven with one broke off in the head. that mean the controller is not staying on long enough. I watched it this AM it stayed on not even 3 sec. Not sure if that is due to missing one GP . I would like to trick it in thinking that it had 8 GP , by pluging the one and just have it lay on the side of the head. this will complete the circuit the Controller would stay on longer.
2- the other problem is fuel pressure leak down over night, it take several cranking to start seeing white puff , indication there is no fuel. I have not found the exact problem
Again thank you all for the support
Norton72
Jul 3, 2012 06:09 AM
montemontana
May 17, 2012 05:51 PM
Byrddog
Mar 3, 2012 07:12 AM
hairyboxnoogle
Aug 16, 2011 11:04 AM
wreckinball
Feb 23, 2010 09:29 AM
