HELP!! My trunk is sending 7 codes
Old Mar 16, 2009 | 11:22 AM
DasCheckers's Avatar
DasCheckers
I would personally recommend cleaning the entire intake and all associated sensors.
You might find what I did.
Throttle Body: Left side is after cleaning, both looked like the right side.
Upper intake manifold:
You might find your throttle body is nasty.
Good luck!
Old Mar 22, 2009 | 02:54 PM
izmepeggy's Avatar
izmepeggy
UPDATE..The truck was running fine except for the idling at stops.Put a new TPS sensor on yesterday.Now it runs worse and back fires.It doesn't shift right either. Shifts at to high RPMs or doesn't want to shift period.We have checked for loose wires and vacumm lines to no end and found nothing wrong.
Old Mar 22, 2009 | 09:44 PM
DasCheckers
You really need a new 02 sensor!
Old Aug 13, 2009 | 04:03 AM
izmepeggy's Avatar
izmepeggy
DasCheckers thought I would let you know the outcome of my truck.After changing every sensor known to men and months of banging my head against the wall.I replaced the PCM.Then 4 injectors were not working.Found out the 58 pin on the new PCM was bad.Got a replacement and now it runs like a scalded dog. I do still plan to clean the intake.Wouldn't hurt..Thanks for your advice
