wastegate
Old Mar 5, 2009 | 05:56 PM
crazer42's Avatar
crazer42
wastegate
i hear the term pulling the red plug a lot. will this eliminate the wastegate opening early. and will it mess anything up?
Old Mar 5, 2009 | 06:00 PM
superduty4x4's Avatar
superduty4x4
Search...
Will it eliminate the wastegate opening early? Yes, that is what it is supposed to accomplish.
Will it mess anything up? Yes, if you run the truck hard enough. A stock truck will be fine, a modded truck you will want gauges. The stock turbo isn't happy or efficient above 25 psi. With just an intake and exhaust and the wastegate unplugged I could hit that boost level without much trouble, now that I have a DP Tuner all it takes is a squish of the skinny pedal to pull 25+psi and set the SES light in the blink of an eye.
