runing fule pump!
Old Mar 5, 2009 | 12:39 AM
patrickkomar's Avatar
patrickkomar
Question runing fule pump!
I have a 1990 f-250 4X2, 5.0l A4OD trans to start this all off with!
And now one to the question/problem, I got out of my truck today and went to go in the house and I heard the tank pump in my back tank running I thought to my self that's odd only chevs do that so I got back in the truck and started it up and flipped the switch to the front tank and shut the truck down and sure enough the pump in the front tank was running so then I timed it and the pump shuts off after 45 sec to 1 min. So what gives? It literly started doing this after I got home from work today and I've owned this truck for about 4 months now.
Old Mar 5, 2009 | 09:01 AM
jas88's Avatar
jas88
Sounds like a sticking fuel pump relay. It's under the hood on top of the driver's side inner fender. When mine did this I was cheap, I drilled a little hole in the top and sprayed it with WD40. Never did it again.
Old Mar 5, 2009 | 09:49 AM
Sportruk's Avatar
Sportruk
My '89 did the same thing. I just put in a new relay.
Old Mar 5, 2009 | 10:23 AM
wolfy's Avatar
wolfy
this relay is located beside my air intake on my 91 I6 4.9l. If you are standing beside the right "drivers" front tire then it should be in front of you bout 6 inches from the fender. or about 6 inches toward the cab the air filter box.
if i am wrong please someone chime in and correct me
Old Mar 5, 2009 | 05:59 PM
patrickkomar
thanks I'll see about tracking it down........ is this part available from the parts store or do i have to go to the dealership to get one? here is the million dollar question....what caused this to happen????? old, worn out, they just do that some times???
Old Mar 5, 2009 | 06:04 PM
quicklook2's Avatar
quicklook2
it is an almost 20 year old part!
go to napa for one, not autozone.
jeffreybruton
Nov 13, 2014 08:21 PM
94GreenTruck
May 23, 2014 09:27 AM
86'F-150
84
Jan 22, 2013 10:33 PM
foolgator1
Jun 14, 2012 12:38 PM
dirtbagHB
1983 - 2012 Ranger & B-Series
Nov 4, 2010 12:37 AM
