Fluids - What to use???
Old Mar 4, 2009 | 09:11 PM
IZZYAZ's Avatar
IZZYAZ
So I have heard conflicting info. on what oil to use in the engine, transmition, transfer case and front and rear ends. So what should I use?
If the weather holds for this weekend I am wanting to replace all the fluids in the truck. It's a 1974 F100 FE390 (from a '66 Mercury), C6 auto (original to the truck), NP205, 9" rear, and Dana 44 front.
So what weights is everyone using for these applications? Also quantitys of all so I can make one trip to the parts store. Is there any advantage to running synthetics everything?
Thanks in advance,
Old Mar 4, 2009 | 09:19 PM
murph77's Avatar
murph77
I run Shell Rotella 15 40 in my 300.
Phosphorus and zinc numbers are very high in this oil.
Many debates that I won't participate in are sure to follow this post.
Murph.
Old Mar 4, 2009 | 09:32 PM
IZZYAZ's Avatar
IZZYAZ
I was running straight 30 wt in the old 360 that was in it. Leaked like a stuck pig with 10w30, so running 30 wt it slowed down to a slow leak. But it didn't like that heavy of oil in the winter at -20.
I guess my biggest issue is with the C6, transfer case and front and rear ends. I just don't want to have to replace something after I just got it all put back together.
Old Mar 4, 2009 | 10:11 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
C6- Use Dexron III or Mercon- 26.5 pints for 1974 4WD...don't forget a new filter!
T-fer case, F100 4WD- SAE140W gear oil- 1.25 pints
Dana 44-71F differential- SAE 90W gear oil- 4.75 pints
if limited slip, add friction additive EST-M2C1 18-A (add 4 oz. to rear, 2 oz. to front)
all Ford differentials- SAE 90W gear oil- 3300 & 3600-6.5 pints
3750- 7 pints
As far as engine oil, I run regular Valvoline 10W-40 in my 360.
Oil leaks? What oil leaks? That's just sweat from all those horses!!
Old Mar 4, 2009 | 11:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
WHOA ... That is in-correct!!
The first year Ford offered Mercon with a C6 (and C4's) was 1977.
Prior years used Type F.
Verbatum from the 1973/79 Ford Passenger Car & Light Truck Parts Catalogs:
XT-2QDX .. Automatic Transmission Fluid "MERCON" - for 1977/ Ford C6, C4 only.
Old Mar 5, 2009 | 12:37 AM
Jermafenser's Avatar
Jermafenser
Transfer case is also incorrect. 140W will never get the thing moving
Some trucks ask to use SAE 50W motor oil, while some other ask for 80w90 gear oil.
Old Mar 5, 2009 | 02:07 AM
Don S.'s Avatar
Don S.
Thanks in advance,
Me personally I switch up Viscosities due to weather changes, but I own a 460, which really shouldn't be that much different. I run thnner oil in the winter 10W30, and 15W40 in the summer.
Just like my car 10W30 in the winterand 20W-50 summer.
Old Mar 5, 2009 | 02:09 PM
Bowtie_Schmowtie
OK...my fault...DexronIII/Mercon for the C6 is what it said in the book that I have at the house- it said that only the C4 uses Type F.
The good news is that now I have a real excuse to chuck it out. I've opened it three times since I've had it, and those three were only for minor things.
The 140W for the T-fer case was a typo...actually I think it said 10W40...or whatever you use in a manual trans...
Sorry for the mixup...I'll leave the numbers to the experts with the REAL manuals.
Old Mar 5, 2009 | 02:24 PM
Jermafenser
10w40 sounds okay, but I don't think it was specced. But it's pretty close to SAE 50W.
Chilton/Haynes is full of inconsistencies. I only trust Ford literature.
Old Mar 5, 2009 | 03:26 PM
Tees77f150's Avatar
Tees77f150
SHHHHOOOOO, glad we got that cleared up! I panicked there for a moment, and though I put the wrong fluid in my C4 a few months back, THANKS NUMBER DUMMY!!!!
Old Mar 5, 2009 | 04:41 PM
Bowtie_Schmowtie
Question, though...if you get a rebuilt pre-77 C4 or C6, would you then use DexronIII/Mercon, or would you still have to use Type F?
I'm guessing it has to do with the band material, right?
_______________________________________________
One more life lesson learned...a twenty dollar manual can cause thousand dollar problems, especially in the hands of a trusting person!
Old Mar 5, 2009 | 05:26 PM
Jermafenser
Good question - I'd call the shop and ask what they did in the rebuild.
jonmammenga
Nov 17, 2014 09:15 PM
Island Time
15
Oct 7, 2014 12:11 PM
miller_feed
21
Oct 11, 2012 12:11 PM
hedhntr
May 2, 2012 10:25 AM
piersol
Dec 25, 2009 09:49 AM
