Differential experts help please!
Old Mar 4, 2009 | 08:06 PM
dkillianjr's Avatar
dkillianjr
Hey guys, I havent posted here in a while. I really havent done much with the truck after rebuilding it. The truck is a 1994 f150 4x4 with a 3.55 LS rearend.
Heres my question. My spider gears are toast the teeth are busted off. I am planning on just picking up a new ford racing trac-lok unit. Now, I was thinking of upgrading to 4.10 gears. This may be a stupid question, but do I need anything special or different to go to 4.10's? Can you guys give me any info or tips you may have?
Thanks, Dave
Old Mar 4, 2009 | 08:17 PM
1966Tbird's Avatar
1966Tbird
nope nothing special for 4.10s as far as i know, my tip would be don't waste your money on the ford racing diff, just get some spider gears off ebay and a clutch rebuild kit and put new clutches in it and if you want more bite you can position the clutches differently in the diff, i forget how to do this though, or you could just weld up the spider gears although that might make it hard to get the C-clips off of your axles.
i just bought some 4.56 gears today if you want me to take step by step pics of the install i will as long as my hands arn't too dirty
Old Mar 4, 2009 | 08:35 PM
Conanski's Avatar
Conanski
The LS in your truck is a Trac-Loc, don't buy another one unless it's busted too, just repack the clutches. When you take it apart you'll find the clutch packs have metal plates back to back instead of alternating with friction plates, restack them so they do alternate, this will require 1 extra friction plate and 1 less steel plate per side.
Old Mar 4, 2009 | 08:47 PM
Rulebreaker's Avatar
Rulebreaker
I would throw a $250 lunchbox locker at it. RB
IIRC you'll need a non LS carrier but that would be cheap from a junk yard.
Old Mar 4, 2009 | 08:59 PM
dkillianjr's Avatar
dkillianjr
Thanks guys for the info so far! So if I want to go with 4.10 gears I have to go with an open diff?
The only reason I was looking at the ford trac-lok unit is cause I was assuming it would be easier to install, since it would be the same as what its replacing and it also will accept the tone ring for the speedo.
I have never really done any rearend work before. I may just keep the 3.55 gears. Would swapping either a trac -lok unit or an aftermarket be a fairly easy job?
I have pulled axles and all that before, I just keep hearing all this stuff about shimming, I thought if I just swapped them it would be simpler?
Thanks again, Dave
Old Mar 4, 2009 | 09:14 PM
Newcomer's Avatar
Newcomer
Tbird, why didnt you just tell him to weld the pinion to the ring gear, then he'd be set. Hah!
Old Mar 4, 2009 | 09:20 PM
1966Tbird's Avatar
1966Tbird
hahahaha yeah be sure to weld up the U joints as well and the brake drums to the backing plates and axles to the housing
(please dont take this serious i would feel bad)
Old Mar 5, 2009 | 12:24 AM
460/5's Avatar
460/5
Zombie Survivalist
ROTFLMAO!!!!!! while your at it, take the PTO cover off and weld up your transfer case chain too.
Old Mar 5, 2009 | 06:00 AM
lew52's Avatar
lew52
I would just put a detriot true trac in it then you wont have to do clutch packs any more...I have one & like it & everone i know does to...Havent heard anything bod about them... They will accept the tone ring...Lew
Old Mar 5, 2009 | 04:56 PM
dkillianjr's Avatar
dkillianjr
Thanks guys, for all the input. I'm still not sure what I am going to do, probly just keep the 3.55 gears. Or I may just weld all the gears together
Thanks, Dave
Old Mar 5, 2009 | 07:22 PM
Blurry94's Avatar
Blurry94
If you're not concerned with mileage, the 4:10's will make a difference. However, with 4.10's, you'll at least want to do a LSD rebuild because traction will become more of an issue. Either way you go (with gears) the limited slip rebuild kits are inexpensive and it fairly easy to rebuild the one you have. One thing I would recommend is to pull the axles completely out and push a rag through the axle tubes, from the outside to the center; a broom stick makes a good push stick.
Old Mar 5, 2009 | 08:59 PM
andym's Avatar
andym
You're forgetting something... if your truck is a 4x4, you need new gears in the front as well.
MacbooknMyTruck
2009 - 2014 F150
Feb 28, 2010 08:51 AM
dave75
Jan 16, 2008 04:27 AM
1996pwrstrk
Dec 13, 2006 11:44 PM
Dave S
Feb 28, 2003 06:33 AM
93bigbronco
1997 - 2003 F150
Jun 1, 2002 09:54 AM
