Sponsored by: Real Truck
Slip Yoke Grease Fitting Mod
Old Apr 28, 2010 | 07:50 PM
  #46
hammer65's Avatar
hammer65
Originally Posted by skoveng
I'm here to provide an up-date on the slip-yoke grease fitting modification.
First, I have not had any problems with the drive line with respects to the yoke end not having a relief vent hole. Once you start having the problem of the "clunking", the blue plastic coating is worn off of the splines, providing plenty of room for any excess grease to find its way out.
I have only been greasing the yoke when I notice the clunking returning during a pull-out from a stop. For me, it's about every 7 to 10K miles.
When greasing, using a standard level-style manual grease gun, I pump about 20 times.
I have about 20K miles on the truck since the modification and have not noticed any grease leaking from the spline boot.
I'm happy with the mod as the clunking when pulling out drives me nuts and ruins the joy of driving the truck.
I'll keep everyone posted at the miles roll on.
If you are having to grease the joint every 7 to 10K. Then the grease must have found a way out.
Before doing the mod, wire tie a small nut to the drive shaft and drive it down the road. It will tell you if you are going to feel the vibration. Jim
Old Apr 29, 2010 | 07:31 AM
  #47
skoveng's Avatar
skoveng
Like I said, it's only been 20K miles since the mod. My thoughts are that I haven't put enough grease in it yet to have found its way out of the boot.
As far as the nut goes, I was not getting a vibration; it was definenitly the lateral play in the yoke.
Old Apr 6, 2011 | 09:44 PM
  #48
honeydew's Avatar
honeydew
Originally Posted by 1975StroppeBaja
Before I did mine, I looked at the eurekaboy write up and my driveshaft was different than his, so I did a write up on what mine was like.
2004 F250 Slip Yoke Service
As shown on my page, I used Valvoline Durablend grease on mine. So far its holding up well.
This forum is great! I've been experiencing a clunk and weirdness on take-off for quite a while. Five minutes of searching found this thread, which led to the link above. Went straight out this evening and cleaned/lubed the slip yoke. Problem is totally gone with no $$ expended! Thanks all!
Old Apr 7, 2011 | 06:25 AM
  #49
knightrider955's Avatar
knightrider955
Heres the way I did it on my 03. I put the grease fitting in the middle of the yoke. I took a 1/16th thick cut off wheel and cut a groove around the spline shaft. Not too deep. Just enough to give the grease a path to get to all the splines around the shaft. Works like a charm. Then I used waterproof marine bearing grease like I use on everything.
Old Apr 7, 2011 | 11:46 AM
  #50
EXv10's Avatar
EXv10
You can cut a bunch of lines in it and it won't hurt it. The problem is the the spline was machined too tightly from Ford.
Old Apr 7, 2011 | 01:40 PM
  #51
knightrider955
It needs to be machined tight otherwise there will be high speed vibrations. Plus putting the grease fitting in the middle allows grease to reach the end without packing too much behind the shaft. Once its full it just forces grease out the other end and Presto!!, the whole thing is greased. The waterproof marine grease keeps the moisture out if the boot isnt sealing all the way.
Old Apr 12, 2011 | 08:09 AM
  #52
5.4f250sd's Avatar
5.4f250sd
Thanks for this write up! I went a head and tapped the driveshaft and installed a zert. I also to a dremel and made a small grove all the way around the shaft for the grease to move all the way around. I greased the shaft and reinstalled it and then added about 5 pumps to the zert. I have no clunk and when I get one back I will pump 5 at a time untill it goes away. Here are some pics!
Old Apr 12, 2011 | 09:18 PM
  #53
EXv10's Avatar
EXv10
Not that tight! I have removed hundreds of driveshafts that had no vibration or tightness problems. I guess there is no easy way to take a few thousandths off all the splines so greasing it and adding grooves around it is the only solution........good going 5.4f.
Old Jul 25, 2011 | 11:46 AM
  #54
R1racer's Avatar
R1racer
Hello every one ..I got 01 F250 W 5.4L ,I was planning on doing the slip yoke service by removing it and grease it , What is the right way to remove it..? Do I have to totally remove the drive line from the rear end or just simply remove the 8mm bolts that holding the u joint in place and pry the slip yoke back to allow it to be released which will keep the drive line attached to the rear end ..?
Old Jul 25, 2011 | 12:49 PM
  #55
krewat's Avatar
krewat
FTE Leadership Emeritus
It's MUCH easier if you remove the entire driveshaft from the vehicle and work on it on the bench (or picnic table, or wherever you have a good flat surface)
Old Jul 25, 2011 | 06:21 PM
  #56
bpounds's Avatar
bpounds
Most important advice I can give you is to chock the tires well! Put the emergency brake on, and put your transmission in neutral.
Mark the shaft where you disassemble it so that it goes back in the same orientation. (At the U-joint. The spline cannot go in wrong)
I'm not a fan of the grease fitting modification, so I just pulled mine out and put a little grease on the splines, and did it right under the truck. Unless you are drilling and tapping for a fitting I see no reason to take the whole shaft out.
Old Jul 25, 2011 | 07:34 PM
  #57
EXv10's Avatar
EXv10
Im not a fan the the zerk mod either, it"s just a spline that takes a little grease. I would put my energy into removing a little material off the spline with a rotary brush on a drill with some grinding compound or some other abrasive.
Old Jul 26, 2011 | 12:10 AM
  #58
twags6's Avatar
twags6
Not sure if you have the two piece driveshaft like mine does, but all I did was unbolt the center bearing and drop it. That pulled the slip joint apart and allowed me to grease it, then put it back in the exact same spot. Mine was so stuck that all 150lbs of me hanging on the driveshaft wouldn't pull it apart!
Old Jul 26, 2011 | 12:57 AM
  #59
EXv10's Avatar
EXv10
Ford screwed up......they are too tight from the factory, that's why they have problems.
Old Jul 26, 2011 | 09:14 AM
  #60
R1racer's Avatar
R1racer
Am not drilling for fitting at all , just want to grease the slipyoke I did go round one with the truck this past weekend but the truck obviously won as I attempt of releasing it from the mid section by the slipyoke, I did what you recommended above with the exception of marking the shaft ,took the 8mm bolts apart hoping the thing will be apart in no time , But it was so stubborn to come out and I didn't pry at all at the U joint by the slip yoke fearing I might screw something up ...So I put things back together and started my forum search ....<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
