This cant be right!
Old Mar 4, 2009 | 10:53 AM
andrew1's Avatar
andrew1
This cant be right!
Okay I bought a 93 f150 5.0 E40D trans in it. I sold my my dodge dakota 4 cylinder for this truck i wanted something a lil bigger. Man was I in for a rude awaking, does this truck get bad gas mileage or it's something i'm doing wrong to da truck. It runs smooth. Please tell me its a mod i can do, To get better gas mileage.
Old Mar 4, 2009 | 11:06 AM
lew52's Avatar
lew52
What milage are you getting..?? It will never get the same as a 4 banger..The bigger the truck & 4x4...??? Good tune up ... Check codes....Alot of performance type mods will help fuel milage...Like the exhaust to start with..Make sure your air filter is clean.. check timming...coast down hills...Lew
Old Mar 4, 2009 | 11:11 AM
HrdDrv's Avatar
HrdDrv
It also doesn't help to have an 18 gallon tank like mine. No sooner your'e enjoyin the ride, your eyes get glued to the gasometer. I feel I'm lucky that's my only problem, there are other's out there with larger truck problems. I don't complain about mileage, I just enjoy the fact that it's movin me down the road.
Surely you will find at FTE the answer(s) you seek to help you out.
Old Mar 4, 2009 | 11:53 AM
quicklook2's Avatar
quicklook2
drive with an egg under the accelerator.
give it a good tuneup.
Old Mar 4, 2009 | 12:13 PM
Conanski's Avatar
Conanski
It should get about 15mpg on average in good running order and with stock size tires. What does it get and what were you expecting?
Old Mar 4, 2009 | 12:34 PM
andrew1's Avatar
andrew1
filled it up maybe did lil 120 miles before i had to refuel again, wasnt on empty maybe lil over 1/4. But i'm coming from a 4 cylinder dodge only reason i got the truck was for hauling. My dodge would pull it but it felt like i was pulling a tank behind.
Old Mar 4, 2009 | 12:46 PM
andrew1's Avatar
andrew1
Is it anything to those performance chips?
that claims better gas mileage
Old Mar 4, 2009 | 01:00 PM
Conanski's Avatar
Conanski
So how much fuel did you add after foing 120miles? The fuel gauge cannot be used to measure milage.
Old Mar 4, 2009 | 01:14 PM
quicklook2's Avatar
quicklook2
have you done a tuneup?
air filter?
read codes?
checked ign. wires, cap/rotor?
etc.
andrew1's Avatar
andrew1
so what do i need? Are those performance chip junk?
Old Mar 4, 2009 | 01:20 PM
andrew1's Avatar
andrew1
changing the air filter 2day, i have autolite plugs, is ther a better brand?
Old Mar 4, 2009 | 01:23 PM
lew52's Avatar
lew52
I would get an acurate reading on your fuel milage first... Fill it up record milage..next time you fill up see how much gas it takes & how many miles you drove..Its a 93 duel tank im guessing..i would think you should get at least 200mi to a tank ?? so if you only get 120 you have a big problem...no chip will help that...Lew
Old Mar 4, 2009 | 01:24 PM
quicklook2's Avatar
quicklook2
stop worrying about a performance chip and tell what you have done or installed.
are they new copper plugs?
answer all the other things i asked with as much detail as you can.
how did filter look?
what does throttle body look like, etc.
Old Mar 4, 2009 | 01:50 PM
Virto's Avatar
Virto
Seriously, this thing weighs a ton compared to what you're used to.
There is no chip that is going to help you with an EECIV.
You need to pull the stored codes and see what's going on behind the scenes. fordfuelinjection.com has the proceedure.
Basic tune up stuff is needed when you buy one of these trucks, and even more so if it's been sitting. Cap, rotor, plugs and wires are a good start. Make sure the air filter is clean and replace if needed. Change the oil if it hasn't been done recently, and you should usually drop the transmission pan and change the filter/fluid.
These trucks will run forever if you take care of them, but they aren't going to be giving you much more than 14mpg with a light touch. Combined, my 2WD 5.0 averages 11-12, but I do a LOT of city driving.
Let us know the codes. Make sure your tires are aired up properly and we'll go from there.
Old Mar 4, 2009 | 04:10 PM
qman's Avatar
qman
We still don't know what your fuel mileage is.
