Modular V10 (6.8l)
Dead V-10
Old Mar 3, 2009 | 11:47 PM
big dude's Avatar
big dude
Dead V-10
While returning from Arizona for the 2nd year my 07 Motorhome started to lose power about 30 miles out of Boise. I was down to 25mph in 1st gear to climb 2 and 3 % grades. I made it to a dealer who checked the computer, no codes. Its top speed was 35 on the flats by then. The engine also developed a ticking sound (sounded like a lifter to me). Dealer drained the oil, had a small amount of glitters in the oil. They called and said the loss of power was because the cat converter was completely plugged.They pulled the pan but never told me what they found. They said when they disconnected the injector on number 10 cylinder the ticking (knock to them) went away. They are now in the process of installing a new long block in the motorhome. My question is what caused the cat converter to plug up? A bad rod wouldn't. Thanks for your input.
Old Mar 4, 2009 | 02:58 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The wrong mixture will fry a cylinder, and could possibly cause the catalytic converter to overheat and melt internally, clogging it up.
Old Mar 4, 2009 | 05:27 PM
big dude's Avatar
big dude
The dealer just called and said the motorhome is finished, going to pick it up tomorrow. Dealer said the mechanic felt that the cat converter came apart inside and clogged up causing exhaust gases to go back into the engine scoring the cylinders and causing piston slap in #10. He said all cylinders were scored, sound likely?
Old Mar 5, 2009 | 10:23 AM
krewat's Avatar
krewat
Maybe...
It certainly would overheat the tops of the pistons causing them to scuff, I would think.
Old Mar 5, 2009 | 02:09 PM
hydro_37's Avatar
hydro_37
You could maybe get an oil analysis done.
Old Mar 5, 2009 | 03:27 PM
Sooper-Doodie's Avatar
Sooper-Doodie
Too late now. LOL.
clint_kelly13
Mar 30, 2014 02:49 PM
yeah its mine
Nov 2, 2013 10:19 AM
mr45auto
Modular V10 (6.8l)
Aug 29, 2010 04:52 PM
hess
1978 - 1996 Big Bronco
Feb 27, 2005 02:46 AM
klnev2004
Oct 1, 2004 02:15 AM
