Removing Bed And Rust-Proofing Frame
Old Mar 3, 2009 | 07:47 PM
Roger T. Pipe's Avatar
Roger T. Pipe
I recently had my truck up on my friend's lift to do the transmission transplant...while under there, I got to see a lot of things I normally don't see..namely rust on my frame! What I want to do is remove the bed from the truck, '96 F250 5.8 4x4 , and sand and strip the frame and coat is with a rust resistant pant (POR-15?) What is involved in removing the bed? I've heard its either 6 or 4 bolts, all located on the bed floor, I presume? Any suggestions as to what to paint onto the frame itself? There is no rust-thru at all, just crusty type rust which doesn't look too good! The rear shackle mounts are especially rusty and I might just replace them while the bed is off. Any opinions or input would be appreciated...
Roger
Old Mar 3, 2009 | 08:03 PM
TMF's Avatar
TMF
Six bolts is what I took off on my '94 F350 w/8' bed... Came out with no heat needed even though truck had been pretty abused and left outside pretty much it's entire life. I scraped off what was crusty and ugly but didn't go so far as you propose because my truck will always be, and stay, ugly. I should have done the shackle mounts then too - much easier when the bed is off so be sure to check the shackles and mounts on both sides, they are prone to rust...
Old Mar 3, 2009 | 08:54 PM
skaterbro's Avatar
skaterbro
Don't forget the wiring for the taillights and the filler neck(s).
POR-15 is great stuff, my buddy used some on his truck. But i did my frame with Eastwoods Rust Encapsulator. Also a good product.
Old Mar 3, 2009 | 09:47 PM
quaddriver's Avatar
quaddriver
find my rusty frame fix photos on my 'new' 90 and see what I did and decide if you need to do the same.
green_95
Jan 12, 2016 03:58 PM
Roger T. Pipe
Jul 1, 2015 12:38 AM
Roger T. Pipe
46
Jul 7, 2014 03:10 PM
Roger T. Pipe
Jan 17, 2011 02:26 AM
jrm1027
Aug 4, 2010 09:24 PM
