E4od ****f problems.
Old Mar 3, 2009 | 07:20 PM
jeffsk7's Avatar
jeffsk7
I have rebuilt e4od tranny with all heavy duty parts and oversized tranny cooler, but it still does not shift that great (ie torque converter slips and does not stay locked up). Can I just buy an updated controller to fix this problem. If so where can I find one and how much.
1993 7.3 Idi 125000 mi 4x4.
Old Mar 3, 2009 | 07:50 PM
David85's Avatar
David85
It could be a valve issue. Did your rebuilder go through all of the valves in the pump and valve body?
I fought valve problems in mine on and off for months before just replacing the valve body with a reconditioned one.
If its a hydraulic problem, then a controller will not affect it. Are the symptoms affected by temperature? (does it clear up or get worse as it warms up?).
Old Mar 3, 2009 | 08:09 PM
jeffsk7's Avatar
jeffsk7
No the problem does not change its the same all the time. Don't know exactly what was went through. I just have the receipts since I bought the truck used. I was just thinking it might be a controller problem sine the early E4od controllers had lock-up and shift problems because that does seem to be what is happening.
Old Mar 3, 2009 | 08:26 PM
bad12jr's Avatar
bad12jr
Check u throttle posistion sensor. Make sure the voltage is right on the side of the IP. Alittle bit of voltage difference may make the computer think the throttle is somewhere where the torque convertor isnt fully locked up when it should be.
If u want a tuneable controller check out Electronic Performance Products -- Baumann Electronic Controls, LLC
I'm gonna get one when i get the money.
Old Mar 3, 2009 | 08:28 PM
bad12jr's Avatar
bad12jr
https://www.ford-trucks.com/forums/8...limp-mode.html
Check this out. I just had to set mine after replacing the one I broke.
Old Mar 3, 2009 | 08:44 PM
jeffsk7's Avatar
jeffsk7
thank's ill check that out
Old Mar 3, 2009 | 11:30 PM
ford trans tech's Avatar
ford trans tech
just so youll know the early E40D processors did not have lock up and or shift problems
that is just some bovine scatlogy spread by those that couldnt diagnose the real issue
Old Mar 4, 2009 | 12:30 AM
David85's Avatar
David85
Never heard that before. My understanding is that all the lockup and shift functions are either on or off with line pressure and shift timing being the only dynamic variable controlled by computer. Shift firmness is still mostly from the transmission internals.
I certainly can't see how a computer glitch could cause these particular symptoms but I have heard of some cases of guys replacing computers and fixing problems. Only 2 cases so far, and I wasn't there.
jmuenchow
Feb 11, 2015 08:09 AM
papajunk
Jan 3, 2011 08:48 PM
peys_daddy08
1978 - 1996 Big Bronco
Dec 27, 2010 11:38 AM
padutch
May 20, 2002 09:26 PM
