9 inch brake offset - very confused
Old 03-03-2009, 07:05 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
next question is can you fit a socket on the bottom nut on the front side, or is the pinion in the way? Maybe you have a 65-66 Mustang 8"? (I pretty much doubt that, though)
Could be an early mustang center section, and truck style tubes and axles, and brakes....lol.
Unfortunately, all of mine are buried in the snow out back.
Old 03-03-2009, 07:15 PM
patience's Avatar
patience
patience is offline
Nope I tried that one. Socket won't fit, so it's a 9". Thank God for that.
Old 03-03-2009, 07:27 PM
havi's Avatar
havi
havi is offline
Ford 9 inch junkyard Questions.. - Pro-Touring.com Here's a pic on this link that shows a 1969 Cougar 351 9" which is what your tag indicates. Notice the tapered ends. If your's is a big bearing, it wouldn't have tapered ends. Should be 3" all the way. Ford 9 inch junkyard Questions.. - Pro-Touring.com
Old 03-04-2009, 02:32 AM
patience's Avatar
patience
patience is offline
Okay, Havi, I've posted a set of pictures on Flickr here with shots of the back and front of the pumpkin, axle ends, flanges, etc.: Ford F100 - a set on Flickr
You can see the pumpkin has two dimples with the fill hole and the axle ends have the two holes with countersink in the middle
And here are all the measurements:
Axle flange-to-flange width: 57"
Axle tube Outer Diameter: 3.125" all the way (no taper)
Bearing size was about 3.15" OD
Flange hole spacing: 3.15" horizontal, 2.375" vertical
Bolt pattern is 5 x 5.5"
28 spline - the axle is tapered
Doing some google searching, the 57" axle width suggest that this is the 57-72 pickup?
High Q Ties - 9" Ford Information and Identification
FORD 9
So with all this, why does my axle offset measure 2.00" when you would expect 2.36"?
And thanks again for all the help.
Old 10-14-2015, 02:39 AM
RSloan55's Avatar
RSloan55
RSloan55 is offline
Just Wondering if you have solved this problem? because im having the exact same problem but my offset is 2 1/16th on my 55 F100 it has all the same measurements as yours as well accept the offset
Old 10-14-2015, 07:19 AM
patience's Avatar
patience
patience is offline
Haha. This thread is more than 5 years old. Best I can figure, the axle flanges were welded retrofits that weren't original, so a completely custom assembly. Feels like that is not uncommon practice. Good luck!
artscott61
13
04-27-2021 01:10 AM
mull3915
06-23-2017 01:59 PM
myfatherinlaws56f100
01-30-2017 08:55 PM
Danthemanmj23
05-30-2016 12:59 AM
fatheroftwo
03-10-2016 11:56 AM
Quick Reply: 9 inch brake offset - very confused
