5'' stack
Old Mar 2, 2009 | 10:00 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
5'' stack
well i just me a 5'' stack off of craigslist it is mitre cut any tips on installin it im gonna go the cheap route and do it myself i was thinkin about using the 90 deg angle at the end of my stock exhaust to run up into the stack would that work alright
Old Mar 2, 2009 | 10:01 PM
jimwilsonmasonry
the stack was 50 bucks and it looks pretty good came off a 03 f350
Old Mar 2, 2009 | 10:39 PM
Oversize's Avatar
Oversize
The 5" single stack w/ a 90 deg elbow off the stock pipe is fairly common with guys who run Hi Pro 's simply due to less bends for BP. It will cause it to sit inward on your bed about 12" forom the bed rail though, so depending on what you haulin your truck just keep that in mind. Not that twin stack are much bette in that regards as you have to do the same aexcept put a Y in after you throught he bed and run the pipes and the floor til you get near the bed rails and the 90's upward. So you still lose bed floor space but easier to put some sort of guard accross the entire width of the bed. That and 5" is the stack size for Big rigs so you can get rain caps and heat shields for them reasonably easy if you want to to dress it up a little more.
