i'm sure you've gone over this a million times,but i have to ask.if i take the stock air filter off and replace it with the 6637 will it match right up?or do i have to change a few things around?thanks in advance!
You will need a 4" od 45degree ell and 1 4"clamp. I used a 3" id pvc ell which is 4" od on my truck works lake a charm though not a pretty as a mandrel bent 4" od steel one but it gets the job done.
i asked for napa gold 6637 and they knew what i was talking about but for some reason couldnt tell me what else i needed as far as putting the filter on
ok im kinda stuck trying to find someone to bend the 4"pipe most that are close only do 3" if i go with the pvc pipe will an elbow work for the 45 degree that i need??
And reading your first post I wasnt sure if you knew but I am stating the obvious. The entire stock filter housing gets removed. Tuck the air temp sensor that comes off the housing into your fender well.
thanks kevin. you wouldnt happen to have any pitchures of what you did with yours?ive seen a couple pitchures and i dont see any elbow's or 45 degree pipes at all.the ones ive seen just look like a small piece of 4" pipe coming off the filter into the black tube. thanks again
