Low oil pressure?
Old Mar 2, 2009 | 07:52 PM
Tom D's Avatar
Tom D
Low oil pressure?
My oil pressure gauge has been reading very low lately so I decided to investigate. I disconnected the wire at the sender and grounded it. The gauge only went up to the middle of the normal operating range. I'm thinking the gauge is defective as it did not swing all the way over. I know the only safe way is to put a direct reading gauge in but I have no good place to mount it without it looking like a"rigged" job. Any suggestions? Can I buy a replacement gauge? I hear Ford gauges SUCK. Any truth to that? Thank you all Tom D
Old Mar 2, 2009 | 09:29 PM
PLC7.3's Avatar
PLC7.3
I don't think it would swing all the way.... best to do a direct reading on the hole for the sender with a manual reading pressure guage. The sender is a switch that powers the guage at 7PSI and above....... don't that make yur inerds warm and fuzzy.
Hot oil pressure is 10PSI at idle and 40-70PSI at 3000 plus RPM.....
Old Mar 2, 2009 | 09:32 PM
LCAM-01XA's Avatar
LCAM-01XA
Gauges don't suck, Ford logic does -till '86 the gauges were actual pressure gauges, but then in '87 some mental midget decided to solder a resistor to the circuit board behind the dash and turn the gauge into an idiot light with a needle attached - it will never read higher than halfway up cause it was never designed to do so. Now, if you are feeling adventurous you can dismantle the dash and perform surgery to the circuit board and ditch the resistor, then replace the sender you have on the engine with an '86 or earlier sender, and then you will have a functioning gauge.
Old Mar 3, 2009 | 06:31 PM
Tom D's Avatar
Tom D
If I was to hook a continuity meter to the sending unit, do you have any idea what I should get for a reading with the engine idle/3000 plus? My gauge previously ran in between the "r" and "m" in normal. Now it runs between "n" and "o". Engine RPM does not seem to make any difference. It could be the sending unit (something else that sucks). I am on my 3rd one in about 8 years. I think putting a T and a mechanical gauge will make me feel better. It might be fine now but low press indications make me nervous. Thanks for the info Peter. Hope you are surviving the tough winter we are having. Regards Tom
Old Mar 3, 2009 | 06:37 PM
Tom D's Avatar
Tom D
And they wonder why the American Auto Manufacturers are in trouble. A sign I would love to post above the engineering Dept of the "Big three" IF YOU HAVE SOMETHING THAT WORKS WELL, DON'T SCREW WITH IT.
I am just nervous that the gauge reads lower than before. I will do as Peter suggested and see what I have. Thanks Tom
Old Mar 3, 2009 | 06:47 PM
starmilt's Avatar
starmilt
For peace of mine nothing can replace a mechanical guage period.
