help needed
Old Mar 2, 2009 | 10:29 AM
mosmrtazz's Avatar
mosmrtazz
help needed
I am needing some help with a 6" skyjacker lift i am going to install on my 01 F 250 super duty. I would like to install this myself but i dont have a area to do it. If I need to pay someone does anyone know of a good place to have it installed at? any help I can get with this is appreciated.
Old Mar 2, 2009 | 12:10 PM
Garden Spyder's Avatar
Garden Spyder
where you located?
Old Mar 2, 2009 | 01:16 PM
mosmrtazz's Avatar
mosmrtazz
about a hour south of kc
Old Mar 2, 2009 | 04:55 PM
HappyJack's Avatar
HappyJack
Which kit did you get? You going to need driveshaft work done?
Old Mar 2, 2009 | 05:47 PM
Garden Spyder
Oh yeah... kind of forgot that when I was thinking about that earlier.. I was thinking we could make it happen with some of the pointy toed people, but the whole drive shaft thing... makes a difference.
Old Mar 2, 2009 | 05:49 PM
Garden Spyder
4x4land in Topeka has been known to do quality work, don't know if they are expensive, just know people say they are good. On the other hand, depending on what lift kit you have and how complete it is, and how much bolt on stuff there is, the pointy toed people around here are very capable.
Old Mar 2, 2009 | 06:02 PM
mosmrtazz's Avatar
mosmrtazz
I dont remember the kit #.The kit that I got has new shocks,leaf springs front & rear,sway bar extensions ,track bar relocation bracket. I was told that I would not need to do anything with the drive shaft until I went higher than 8 " of lift.
Old Mar 2, 2009 | 06:03 PM
mosmrtazz's Avatar
mosmrtazz
I had a place to do all the work but the doors are not big enough to get it out after the lift is put on
Old Mar 2, 2009 | 08:07 PM
Garden Spyder
would letting the air out of the tires help? what about taking the wheels off of the front, and putting the front on a floor jack, then using the jack to roll it out.
Old Mar 2, 2009 | 08:29 PM
fordboy_52's Avatar
fordboy_52
dam, curtis stole my idea.........
ive rolled a truck out of a shop with a chain and another truck dragging it before.... wood blocks under the axel worked like a charm
Old Mar 2, 2009 | 08:46 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I had a knew a guy that used to put steel rims without tires on his rig to get it in and out of the garage.
Old Mar 2, 2009 | 08:50 PM
Garden Spyder
Was his name Tony?
Old Mar 3, 2009 | 09:10 AM
mosmrtazz's Avatar
mosmrtazz
I did that already it cleared by about a half inch with a 3"lift so i know it won't work with a 6" lift thanks for the idea
Old Mar 3, 2009 | 09:20 AM
HappyJack's Avatar
HappyJack
We have been having some nice weather down this way. If it's the base kit and not the coil over kit it shouldn't take more than a day. Just the regular stuff with spring eye bolts and the instructions I looked at I just saw one bracket that needed some cutting or grinding and a hole that needed to be drilled. Just wait for a nice day and do it outside. I'd check the spring eye bolts ahead of time and soak them with PB blaster to make sure they will come out. If they need to be cut out then you can get replacements ahead of time.
Old Mar 3, 2009 | 02:10 PM
Garden Spyder
Yep, I did mine in the garage but outside would have been so much better (except it was something like 4 degrees outside when I did mine, so I put up with the small problems that the garage presented for the obvious benefit of not freezing to death.
Should be getting pretty nice here in the near future, I think I would do it outside.
