moves like a turtle
Old Mar 1, 2009 | 01:32 PM
billssp88's Avatar
billssp88
moves like a turtle
My 2002 f250 7,3 liter moves like a turtle when cold,when warms up it runs good,any suggestions?
Old Mar 1, 2009 | 01:41 PM
schlepprock250's Avatar
schlepprock250
Could be the nature of the beast....just my .02 worth.
Phil
Old Mar 1, 2009 | 01:52 PM
mxracer3276's Avatar
mxracer3276
Does it sound like a jet engine, blowing lots of air...? If so this is you EBPV, it helps your truck warm up fast but it will not go anywhere.
Old Mar 1, 2009 | 01:57 PM
billssp88's Avatar
billssp88
no,doesn't sound like it's blowing air,sounds normal just will hardly move when cold.
Old Mar 1, 2009 | 01:59 PM
mxracer3276
Then i would have to agree with Phil up there and say yeah it is just the nature of the diesel. Mine does not like to accelerate at all when it's cold.
Old Mar 1, 2009 | 02:04 PM
billssp88's Avatar
billssp88
Thanks,how long does it take yours until it will run normal?
Old Mar 1, 2009 | 02:19 PM
mxracer3276
Depending on how cold, about 5-10 minutes down the road it usually runs better.
Old Mar 1, 2009 | 02:20 PM
zx250's Avatar
zx250
Of the next Riffraff East
How cold are you talking about? Mine's sluggish, but after a minutes or so it's good. Might be time for fresh oil and tranny fluid.
Old Mar 1, 2009 | 02:22 PM
mxracer3276
Another great point, i did just change all of my fluids, so it runs smoothly after only a couple minutes.
Old Mar 1, 2009 | 02:27 PM
billssp88's Avatar
billssp88
Yeah just had tranny serviced and oil changed,actually the injector pump went out so changed the oil,that hurt the pocket book.
Old Mar 1, 2009 | 02:29 PM
zx250's Avatar
zx250
Is this a new problem? Is it more sluggish that last year? Injector pump went out?
Old Mar 1, 2009 | 02:30 PM
mxracer3276
Yeah that being the case, it should not take more then a few minutes to run normal, once again, depending on how cold it is.
Old Mar 1, 2009 | 02:38 PM
billssp88's Avatar
billssp88
actually just purchased the truck and got it home and started leaking oil,ended up being the injection pump,750.00 for pump alone.i've owned 3 other 7.3's and dont remember them taking so long to warm up,but they might of.This one takes about 3to5 minutes to warm up.
Old Mar 1, 2009 | 02:42 PM
jdecker88's Avatar
jdecker88
I promise you it wasn't an injection pump we have High Pressure Oil Pumps, switch to syn. and your truck will run alot better but also until it is warm it runs slow because 15quarts of oil takes a bit to warm up and these trucks fire there injectors off of them the draw backs of a HEUI injection system
Old Mar 1, 2009 | 02:50 PM
billssp88's Avatar
billssp88
Yeah your right,it was the high pressure oil pump.The mechanic said there is some electronic sensor or something telling it when to give fuel when it is cold,that might be the problem,dont know if this is bs or not.
E Bjornstad
Oil & Lubrication
Apr 9, 2017 09:26 PM
timmyboy76
Oct 29, 2013 01:24 PM
GAMBUCKEYE
2004 - 2008 F150
17
May 29, 2006 08:07 PM
OKMIC1
Nov 16, 2001 07:47 PM
