Not yet Neil. The dealer is still working on it. They found a few more problems than the wheel bearing.
That does not sound good. I have an occassional grinding sound from the rear when it is really wet out. It only does it after the truck has sat awhile and I have had the garage look at it and they can not find anything wrong.
Lets see they are putting in new upper and lower ball joints, new wheel bearing and hub assembly,new upper control arm due to the design of the upper ball joints, new idler arm, an alignment, and tighten up the lash in the steering gear box.
