AOD Tranmission
Old Feb 28, 2009 | 11:40 PM
Ranger92's Avatar
Ranger92
AOD Tranmission
What would cause an AOD transmission to require an extra quart of fluid or so to not slip? Is this a sign of impending failure or wear? I have a Crown Vic with this problem. Any ideas?
Old Mar 1, 2009 | 07:13 AM
Lazy K's Avatar
Lazy K
I wonder if it has a plug-in type fluid filter? If it does then the filter may be dislodged.
Old Mar 1, 2009 | 09:34 AM
jk080's Avatar
jk080
Transmission Rebuilder
someone may have forgot to use the cork gasket on the filter
Old Mar 1, 2009 | 12:39 PM
Ranger92's Avatar
Ranger92
Can this happen while being driven?
Old Mar 1, 2009 | 12:47 PM
Ranger92's Avatar
Ranger92
This car just recently started delaying going into gear, or acting like it was in neutral when actually in drive. It would grab if you revved the car up a little while in drive, so I added more fluid and it started working. It had not been serviced for about a year, and I checked the fluid level and it was right. The only problem is the fluid tends to leak out around the fill tube when you turn the car off. Any ideas how to fix this? Thank you.
Old Mar 2, 2009 | 09:07 PM
aaron ford's Avatar
aaron ford
Sounds like the filter may have fallen out of the valve body.
Just a guess...
Aaron
Old Mar 10, 2009 | 10:45 AM
Ranger92's Avatar
Ranger92
Just a guess...
Aaron
Ya, it was the filter! It's back to normal now and I love driving it!
