RUST HELP
Old Sep 8, 2002 | 12:02 PM
Vampiro's Avatar
Vampiro
RUST HELP
Old Sep 30, 2002 | 11:02 AM
noremac19's Avatar
noremac19
RUST HELP
Ok guys, i have a 94 f-150, it seems to be rusting from the inside out, above the rear wheelwells and right at the very back where there is a structural brace. is there a way to stop the rusting, and cover it up some how??? Its not that bad yet, it just looks like surface rust(but i know it isnt). I was thinking to get those plastic things to put around the wheelwells, and maybe a chrome jobby to run along the bottom portion of the truck. Any cheaper ideas??????
Old Sep 30, 2002 | 03:08 PM
mooktank's Avatar
mooktank
RUST HELP
mine rotted allthe way out to crap. I got rid of as much rust as possible, coated it in hammerite or equivalent, bent up a piece of sheet metal aluminum to shape the contour, lumber locked it in. Then i used bondo ULTIMATE and shaped the wheel well. Then i painted the whole underside in hammerite. that stuff is the stuff.
Old Sep 30, 2002 | 04:11 PM
noremac19's Avatar
noremac19
RUST HELP
Thats all good, but mine isnt all the way through. Its just starting, Should i buy a can of under coat and spraiy the wheel wells??
Old Oct 3, 2002 | 03:33 PM
karljay's Avatar
karljay
RUST HELP
No, you must treat the rust with something. For light surface rust I use phosporic acid from home depot for about $8/qt. I sandblast or wire brush the area and then clean with acetone then spray on phosporic acid (called prime and prep I think). Then it dries overnight and I scuff, clean and cover with filler or epoxy primer.
The point is that you must treat the rust, covering it up won't make it go away.
Old Oct 3, 2002 | 05:01 PM
noremac19's Avatar
noremac19
RUST HELP
How can you treat the rust if its rusting from the inside out?Im positive that the rust started inside the wheel well. I finally got my ranger today...yippy Now i have to sell the F-150.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
