Sponsored by: Real Truck
pulling right fixed!!!
Old Feb 28, 2009 | 12:51 PM
muncle's Avatar
muncle
JUst got new rotors from dealer. (i know, like my wife says, I'v got more dollars than sense) and truck was pulling badly to the right. After couple hundred miles no diffence so I took it back. Dealer called to say its done and said one rotor was thicker than the other so they turned it. I'm thinkin no way its right, makes no sense to me. Anyhoo, it freakin worked. Any ideas as to why?
It's a 99 super duty with 118000
Old Feb 28, 2009 | 03:38 PM
ReAX's Avatar
ReAX
There is no bias left to right, ideally both rotors should create equal drag. One was not, although it should have only pulled during braking because the thicker one was dragging sooner.
Old Feb 28, 2009 | 06:20 PM
muncle's Avatar
muncle
Thanks ReAx, I forgot to mention it was just during braking. In my mind, since each caliper slides it shouldn't matter if a rotor is thicker. I am not a mechanic and have no experience with brakes. Does only one side of the caliper slide? Thanks again for the reply.
Old Feb 28, 2009 | 06:43 PM
99f350sd's Avatar
99f350sd
Sounds like a lot of crap..
Dick
Old Feb 28, 2009 | 07:45 PM
ReAX's Avatar
ReAX
Why? The caliper's can't tell so much if the area it's squeezing is thinner than the other. Until there is enough pressure to compress the thin side more than the thick side, the thick side is going to drag more/earlier. Once you achieve enough pressure where the caliper is fighting back, then there should be a pressure differential between the two calipers. I believe the master cylinder pushes out several hundred pounds of pressure, I don't think that it's going to start squeezing the thin side more until the pad stops compressing.
It's all theory to me, but it seems sound enough.
Old Feb 28, 2009 | 07:49 PM
ReAX's Avatar
ReAX
Although thinking about it more, it's actually got a volume component. So you press X volume of fluid at a constant pressure in both calipers. The one that has to travel farther has to fill more space than caliper that doesn't. Perhaps they do have to equalize a little in volume, but because brake fluid isn't compressible I don't think it will fill in with less pressure, but there will be less pressure on the side that has to move the furthest.
Old Feb 28, 2009 | 08:10 PM
99f350sd's Avatar
99f350sd
Calipers always squeeze to the rotor thickness and then back off about .020 when pedal is released so there isn't any difference in regards to rotor thickness and brake force. his problem was pin related most likely..
Dick
Old Feb 28, 2009 | 08:20 PM
bubbasz1's Avatar
bubbasz1
I agree, pin's or something else they missed or screwed up on, I can't see the rotor thickness BS at all.
Old Mar 1, 2009 | 12:38 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Definitely agree... something else was going on.
The thickness of the rotor doesn't matter when it comes to braking ability. The heat dissipation changes, but it's not going to make a difference all the time.
I bet the pins on one side were sticking.
Old Mar 1, 2009 | 08:29 PM
bayou barataria's Avatar
bayou barataria
I have replaced many rotors om my trucks over the years, and most of them have been different thicknesses And have never had a pulling problem. Must be something else, maybe a caliper sticking or something.
