Slow battery drain ?
Old Nov 27, 2010 | 03:37 PM
Farmer41's Avatar
Farmer41
Forgot about this post until the auto notification. Early in the summer the brake controller quit. When I picked up the new one the guys at the RV store mentioned that the old controller could have been the culprit.
Got tired of fighting it and just put on a battery tender.
Jim
Old Dec 8, 2010 | 03:37 PM
Jimmeh33's Avatar
Jimmeh33
Whats a battery tender?
Old Dec 8, 2010 | 06:35 PM
Fishin76's Avatar
Fishin76
Battery tender is a float charger. It will maintain the batteries charge without overcharging.
Old Jan 13, 2011 | 09:04 PM
calexandre69's Avatar
calexandre69
Battery drain - Solved!
Replacing the guage cluster did the trick! No more battery drain. It cost me about $650 at the dealer. The part was about $450. The dome lights are tied to the same fuse as the cluster. Try disconnecting the positive drivers side battery terminal. Attach the positive meter lead to the positive side of the battery and the negative to the terminal and set your meter on dc amps to check the amount of draw. It takes a few minutes to charge the capacitors and will have an initial draw of about .45 amps. with the fuse in but then it should drop down to around .015 . This is normal. Then try the same test with the fuse pulled. Mine was never dropping down until the cluster was replaced. Hope this helps.
Good luck!
Old May 24, 2012 | 09:29 AM
porbuie's Avatar
porbuie
battery drain
two days 20 hours later and 300 in parts changes. batterys discharged, to begin with, over several days and discharge became more rapid over time. seems to be a common problem. i too checked milaamp draw after disconnecting negative battery connections and checked all circuts. #3 fuse and # 1 relay were showing first 60 millia then ol (overload). the readings were bouncing back and forth sometimes and just ol other times. when i made the link with my tester from negative terminal to one of my negative battery post,on the battery, number 1 relay and my dome light would accuate in conjunction with each other (flick on and off). the problem was i had a short in one of the batteries which manifisted itself in my electric system. it was verry hard to diagnose because of the duel battery setup. if you are having this problem when you jump or charge your batteries, to start your truck, if either your terminals at battery connections or the battery heats just alittle your battery may not show bad when tested. lots of work and worry later my battery drain was simply a bad battery. when i found it i was to the point of taking it to the delership.
Old May 25, 2012 | 12:10 AM
MauleOne's Avatar
MauleOne
Voltage Draw
I had a similar problem with my wifes brand x truck. Turned out to be the delay relay that kept the inside lights on for a few minuites after you leave the truck.
It would turn the lights back on after the truck sat for a while and that would kill the battery in a few days.
I pulled the fuse on it and the problem went away.
Yoam69
Apr 7, 2014 10:35 PM
Spotty
1997 - 2003 F150
Dec 20, 2013 05:23 PM
jmassimilla
Mar 1, 2011 11:28 AM
86ford302
13
Sep 18, 2009 07:30 PM
jenkinsj
Electrical Systems/Wiring
13
Dec 3, 2005 03:48 PM
