Sponsored by: Real Truck
Front End Transformation ?
Old Feb 27, 2009 | 12:53 PM
RenegadeF250's Avatar
RenegadeF250
I have a 2004 F250 5.4L 2wd supercab and i was doing some research on what exactly i would have to get to change the front end of my 04 to the 05-07 front end. So far i have figured it would need new headlights and the new grille. My question is does the bumper change? Also i have a grille guard that bolts up to where the tow hooks are at and if i change the bumper does that mounting location change as well? My plans are to add a pro comp 6" lift down the road in case that provides an issue with the front end conversion. Will eveything bolt right up or will i have to trim or mod anything?
Old Feb 27, 2009 | 04:04 PM
Beerstalker's Avatar
Beerstalker
You can keep your bumper, but you will have to trim the 05-07 grill o fit with it. If you replace the bumper you don't have to trim the grill.
You can either cut the header panel to get the headlights to fit, or you can replace the header panel.
Your grille guard should be fine no matter what you do.
f250guy24
Sep 24, 2017 04:25 PM
redtanrt10
Dec 23, 2012 11:25 AM
Mr.blackmer
Jan 1, 2011 07:28 PM
silly34
Appearance & Dress-Up
May 18, 2009 07:35 AM
FLJ
Paint & Bodywork
Sep 1, 2007 08:02 AM
