powerstroke not running
Old Feb 26, 2009 | 05:14 PM
snowsf250's Avatar
snowsf250
hey guys a friend of mine bough a 1996 powerstroke diesel a couple months ago. it didnt run when he bought it but the guy said that it had algea in the tank. we cleaned the tank and lines cleaned the injecters it has good compressin we had it running but it was only firering on 4cylinders on the one side. we also put a new oil pressure regulater on it do you guys no whats wrong. the truck has 300,000 miles on it. we ran out of ideas. any suggestions would be alot of help. thanxs
Old Feb 26, 2009 | 06:02 PM
Welk49's Avatar
Welk49
Check the wiring harness for the injectors on both the inside and outside of the valve covers
Old Feb 26, 2009 | 06:20 PM
snowsf250's Avatar
snowsf250
k thanks anything else if that might not work?
Old Feb 26, 2009 | 08:07 PM
Welk49's Avatar
Welk49
If it cranks watch the tach to see if it moves, if not replace the CPS
Old Feb 26, 2009 | 08:30 PM
97biostroke's Avatar
97biostroke
My truck was only running on four cylinders awhile back. Turned out to be the wiring to the injectors.
Old Feb 26, 2009 | 08:52 PM
tjbeggs's Avatar
tjbeggs
Yep you either have an injector wiring issue or the IDM is bad.
Old Feb 27, 2009 | 07:41 PM
snowsf250's Avatar
snowsf250
we checked the wiring and we replaced it so i dont think thats the problem but was is the idm or the cps? what do they do? and how much are they?
Old Feb 28, 2009 | 08:00 AM
jeep1947's Avatar
jeep1947
CPS is the cam position sensor it is cheap and easy to change about $25 at autozone or napa. IDM is the Injector Drive Module it take the info from the Engine Control Moniter (computer) and tells the injectors when to fire. Expensive from dealer but you can usually find one on ebay for a couple hundred dollars. It is located on the drivers side inner fender, you may just unplug it 5/16" socket check pins and plug it back in. Hope this helps.
Old Feb 28, 2009 | 04:07 PM
snowsf250's Avatar
snowsf250
ok thanxs we will check those and hopefully that fixes it.
