power window stuck closed
Old Feb 26, 2009 | 12:25 AM
Bubbatruck's Avatar
Bubbatruck
Any suggestions on where to begin search out why my driver's side power window has quit working? All the other windows work fine. If I push the button in either direction I hear a clicking sound similar to the turn signal relay.
Old Feb 26, 2009 | 12:42 AM
triskit16's Avatar
triskit16
Motor might be done for. Take off the panel and see if the plug is gettin any power to it. If it is, you might need a new motor.
Could be binded somehow as well...gotta get in there to tell though!
Old Feb 26, 2009 | 06:52 AM
Supercab's Avatar
Supercab
Wink
If you are hearing a click-click-click in either dirrection then your motor is most likely ok, its just the "gear kit" inside-these are easy to replace and cheaper than a new motor, you will have to remove the motor though to service/replace the "gear kit" the kits are sold in most chain parts stores.
Old Feb 26, 2009 | 07:10 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Also if it is the "gear Kit" you can use a 3/8" dia dowel to replace those plastic pieces that have broke. Mine broke several years ago and I used the dowel method and they are still working good.
Old Feb 26, 2009 | 07:22 AM
megawatt00's Avatar
megawatt00
This is great info guys. My drivers side window acts up from time to time. If I leave it cracked open and it sticks I can wiggle it to get it working. I'll have to pull it apart when it gers warmer.
Old Feb 26, 2009 | 12:14 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Mine had quit working in the down position one cold morining on my way to get hardwood for the winter. It ended up being the switch, which came from Ford as a set, cost was like $76 from Y2K. You gotta figure the drivers window is the one that is always getting used and it only uses a small rocker style contact assembly that had wore out in mine. Just another possible cause.
Good Luck, at least it is not stuck open in the winter like mine was.
Old Feb 26, 2009 | 10:32 PM
Bubbatruck's Avatar
Bubbatruck
Thanks for the info guys. Any tips on how to get the door panel off or things not to do?
Old Feb 26, 2009 | 11:17 PM
megawatt00's Avatar
megawatt00
How's this With pics!!!
Door panel removal
Old Feb 28, 2009 | 10:55 PM
Bubbatruck's Avatar
Bubbatruck
Megawatt00
I'd say that is pretty dang cool and just what the doc ordered.
Thanks a bunch for that link.
Dwight
Old Mar 1, 2009 | 07:19 AM
megawatt00's Avatar
megawatt00
Originally Posted by Bubbatruck
Megawatt00
Dwight
Your more than welcome Dwight.
Please let us know what you find when you pull it apart.
Old Mar 1, 2009 | 08:42 AM
DieselCamper01's Avatar
DieselCamper01
I do not have a fancy link like Jim does ( lol ) but isn't there a homemade fix for the door switch? Something super cheap with aluminum foil? Or am I just talking out of my rear end?
Old Mar 10, 2009 | 11:43 AM
Bubbatruck's Avatar
Bubbatruck
I have not had a chance to work on it until yesterday so here is what I have found out so far. The 4th relay under the driver's side dash is the one clicking. The circuit breaker in the power distribution block under the hood checks out fine with an ohm meter. I switched the three different relays under the dash around with no change. With a test light I can make the relay click by jumping the hot pin on the switch plug to either the down pin or the auto pin.
So if I understand this correctly do I have a wiring shorting some where between the relay and the switch? The one thing I forgot to check while I had the door panel off was whether the motor is getting any power when the switch is operating.
Old Mar 10, 2009 | 12:14 PM
tdpower's Avatar
tdpower
re
I think that fix is for the door lock actuator.
Old Mar 10, 2009 | 01:55 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
My back windows get stuck down on hot days (100+). After driving for about 15 minutes they will go back up. I figured the innards just got hot and expanded.
99 F-350 4 door dually, 4" from turbo, SuperChips programmer, 6637
