Head options
Old Mar 9, 2009 | 12:12 AM
Bear 45/70's Avatar
Bear 45/70
Accelerator pump either not working or too lean. Valve timing off. To much carb. Vacuum advance hooked to manifold vacuum and not ported vacuum. It could be a lot of things. You will have to recheck some things and test others, it's called troubleshooting, to find out what isn't as it should be.
