quick question
Old Feb 25, 2009 | 10:07 PM
colorsink's Avatar
colorsink
quick question
hi i have an 85 f150 302 auto 2wd and the emission light is on. what should i check to see what is causing this thanx
Old Feb 25, 2009 | 10:35 PM
Franklin2's Avatar
Franklin2
The CHECK ENGINE or SERVICE ENGINE SOON dashboard warning lamp is referred to as the Malfunction Indicator Lamp (MIL). The lamp is connected to the engine control assembly and will alert the driver to certain malfunctions within the EEC-IV system. When the lamp is lit, the ECA has detected a fault and stored an identity code in memory.
Does it say "check engine" or "service engine soon".
Old Feb 25, 2009 | 10:36 PM
displacement4me's Avatar
displacement4me
this was mentioned a few pages back. with our trucks, the light simply comes on periodically. nothing to fix. and no computer to pull codes from.
Old Feb 25, 2009 | 10:38 PM
displacement4me
that is if its the emissions light up near the right signal light
Old Feb 26, 2009 | 05:45 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
This is just a timer and is called the "extended useful life" sensor, on my truck is up under the dash above the steering column near the chime.
Just another reason to get your truck in to the dealer for a service and inspection.
It can be reset by depressing a button with a pointy tool.
Let me see if I can find my post, or do a search for yourself.
It's easy to do.
EDIT:
Here you go....
https://www.ford-trucks.com/forums/s...73&postcount=6
Last edited by ArdWrknTrk; Feb 26, 2009 at 06:41 AM. Reason: add link to procedure
Old Feb 26, 2009 | 09:29 AM
colorsink's Avatar
colorsink
thanx guys for the quick response
rusty48
Jul 10, 2016 07:00 PM
GotLift
Mar 3, 2004 02:30 AM
jakegypsum
May 10, 2002 09:12 AM
billyb
May 12, 2001 10:56 PM
Pastmaster
Exhaust Systems
Mar 17, 2001 01:25 AM
