6637 Airbox
Old Feb 25, 2009 | 05:56 PM
Ziggy.'s Avatar
Ziggy.
6637 Airbox
Ok guys, I finally got around to getting rid of the chatty K&N. The 6637 came in the other day and I picked up some 4" exhaust pipe. I made an airbox the other day after work, and got it painted and installed today, I was lucky and scored a piece of scrap Lexan that I put to use too. The only 2 ways for air to get into the air box is throught the side where the fender hole is, and from the zoodad mod in the front. Let me know what you all think, good bad and ugly. The only thing left, i've got to take the lexan lid back off and trim it some, but I was trying to hurry to get some pics for you guys before it got too dark.
Old Feb 25, 2009 | 06:08 PM
husker's Avatar
husker
Looks nice. I'm getting ready to do a 6637 myself and have been contemplating how to do an air box to keep down the noise in the cab.
Old Feb 25, 2009 | 06:14 PM
Ziggy.'s Avatar
Ziggy.
When I got the truck it had a K&N FIPK intake on it with the L shaped sheetmetal guard. The bigger 6637 is quieter than the K&N was. I may see what difference it would make another day with the lexan lid off vs. on.
Old Feb 25, 2009 | 06:16 PM
Adam0331's Avatar
Adam0331
That looks pretty nice Cory.
Old Feb 25, 2009 | 06:19 PM
Ziggy.'s Avatar
Ziggy.
Thanks adam, just need to get a cover from pete and i'll be happy with it.
Old Feb 25, 2009 | 06:25 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
great job Cory. looks like Pro job....
Old Feb 25, 2009 | 07:23 PM
F350-6's Avatar
F350-6
That looks good. I'd recommend a piece of screen over the zoodad to keep the big stuff out. What did you do with your other battery. The way the filter is angled and the position of the box doesn't look like it leaves room for the 2nd battery in the usual spot.
Old Feb 25, 2009 | 07:28 PM
Ziggy.'s Avatar
Ziggy.
Here sometime in the next few weeks i'm going to make the piece that goes up to the zoodad out of metal instead of the stock plastic one, and when I do, I'm planning on taking some fine expanded metal from work and putting over the inlet, I just havent gotten that far yet.
And the other battery has been relocated to the tool box for now. I may end up later on going to a larger single battery, but I havent decided yet.
Old Feb 25, 2009 | 08:53 PM
jdecker88's Avatar
jdecker88
Awesome Job man I am next now .
Old Feb 25, 2009 | 08:56 PM
Ziggy.'s Avatar
Ziggy.
I'll get some measurements off yours here one day soon, you'll still be able to keep the batt in the same spot, and i've still got enough lexan left over for a lid for yours too.
Old Feb 25, 2009 | 09:10 PM
jdecker88's Avatar
jdecker88
I'll talk to you tomorrow a bit more on what I'd like to do. If you want to go with a big battery like you said I'll buy yours since they are fairly new.
Old Feb 25, 2009 | 09:22 PM
Ziggy.'s Avatar
Ziggy.
Give me a little while to get around to getting a big single and these 2 are yours then
Old Feb 25, 2009 | 09:31 PM
jdecker88's Avatar
jdecker88
Could you set a big single on the passenger side of the truck if you moved your washer fluid res but I know you want the most room you can get.
Old Feb 25, 2009 | 09:35 PM
Ziggy.'s Avatar
Ziggy.
I'm going to end up deleting the wash tank anyways and just tap into my water meth plumbing. And i'm thinking of putting the vac tank where the wash tank is now, and making a different mounting plate for a big single. I ought to have plenty of room
Old Feb 25, 2009 | 10:07 PM
crum71's Avatar
crum71
1/8 mile Oval Track
could you just use like window screen in front of the zoodad? You know to keep the bugs out and stuff. And by the way that thing looks cool
